will an Ibanez 7 string neck fit a jackson - Jemsite
post #1 of 8 (permalink) Old 08-13-2004, 11:23 PM Thread Starter
Well will it? Jacksons are 22 fret I dont know if Ibanez has 22 fret neck..
Ibanut is offline
post #2 of 8 (permalink) Old 08-13-2004, 11:26 PM
Nope, most Ibanez 7-strings are 24-fretters. With the exception of I think the short-lived S-series 7-string.
Two hands31 is offline
post #3 of 8 (permalink) Old 08-14-2004, 11:15 PM
The cheaper Gio 7 string had a 22 fret neck as well I believe. I like the neck shape on my Gio a lot, so you might want to check it out!
Jeff is offline
post #4 of 8 (permalink) Old 08-15-2004, 12:17 AM
trajectory fish is offline
post #5 of 8 (permalink) Old 10-02-2004, 11:01 PM
jemaholic's Avatar
NOPE.
jemaholic is offline
post #6 of 8 (permalink) Old 10-03-2004, 05:38 AM
Originally Posted by jemaholic
NOPE.
Proclamation upheld.
Shakma!! is offline
post #7 of 8 (permalink) Old 10-03-2004, 12:07 PM
As a Cuban auto mechanic once said, "Does it fit? Everything fits!"
That is to say, yes, it will fit, but not without significant modification to the body and/or neck. Don't forget that most Ibanez necks also come with the All-Access Neck Joint, which mates up to the body in a different way than standard plate-mounted square-heel bolt-on neck joints.
darren wilson is offline
post #8 of 8 (permalink) Old 10-04-2004, 01:14 AM
Not to mention that 7-string neck joints vary even more than 6-string joints...
rory is offline
access neck joint , darren wilson , fret neck , ibanez neck , ibanez necks , neck joint , neck joints , neck shape
Ibanez Iron Label RG 6 String vs. Jackson DK2M Pro Series Dinky 6 String ? Riley Macdonald All Other Guitars (including Prestige) 6 06-16-2013 01:35 AM
FS: Ibanez 7-string body and neck, DiMarzio 7-string pickups, ... bwherry Classified Ads: Guitars and Gear 13 08-12-2008 02:05 AM
wtt upgraded 7321 for fb or string thru ibanez or jackson krylon Classified Ads: Guitars and Gear 11 03-15-2008 07:42 PM
jackson 7 string neck Ibanut All Other Guitars (including Prestige) 0 06-18-2004 03:03 PM
