will a Rg neck fit and work on a saber body? - Jemsite
post #1 of 8 (permalink) Old 12-16-2005, 12:54 AM Thread Starter
werd?
serranasweep is offline
post #2 of 8 (permalink) Old 12-16-2005, 12:58 AM
Re: will a Rg neck fit and work on a saber body?
i think it will if it has the same neck joint..in other word if the bolt holes are the same pattern on the neck and on the body
kelmaur is offline
post #3 of 8 (permalink) Old 12-16-2005, 03:01 AM
No it won't because RG necks are 24 fret and Sabers are 22. So the guitar would never intonate.
Regards
André
fettouhi is offline
post #4 of 8 (permalink) Old 12-16-2005, 03:27 AM
What if... the neck humbucker, is converted to a single coil? And the neck pushed back to where a 24 fret should be?
Shredcows is offline
post #5 of 8 (permalink) Old 12-16-2005, 07:35 AM
Don't know I still think you would need to move the trem .
Regards
André
fettouhi is offline
post #6 of 8 (permalink) Old 12-16-2005, 08:00 AM
i dont think you would neede to move the trem, but you would need to replace the neck more accurately than you can imagine to get the intonation right, and that would take a lot of routing and cutting etc. to do all that
Robot Boy is offline
post #7 of 8 (permalink) Old 12-16-2005, 01:04 PM
Okay this is getting off all wrong from the start. The first thing to establish is what neck joint you have (which can not be ascertained from "werd") LOL
If it's the AANJ then there's no point in trying. Fettouhi is right, they might fit in eachother's pocket, but the extra two frets make it a total waste of time.
If they BOTH are the old style neck joint, then absolutely it will work. But it would require you to saw off the last two frets (otherwise they'd crash into the neck pickup) AND you may have to shave down the underside of the fretboard. On an RG, the fretboard extension has extra wood from the neck under it. That was done to stabilize it, since it's a long extension. It would be more likely to curl and warp without it. If you cut it down to 22 frets you don't need that extra thickness. But more importantly, you can't have that extra thickness because the body isn't cut away for it like the RG's were. The fretboard might hit the guitar's top before the neck sits flush in the pocket. If that happens, you'll crack and lift the board off when you tighten the neck screws.
frankfalbo is offline
post #8 of 8 (permalink) Old 12-16-2005, 01:15 PM Thread Starter
forsure guys, thanks
neck humbucker , neck joint , neck pickup , neck screws
JS guitars.. 22 frets or ? Would S neck work on JS body? HoosierDaddy All Other Guitars (including Prestige) 4 12-26-2012 11:54 AM
WTB: Saber body for project fly_with_v Classified Ads: Guitars and Gear 3 12-21-2012 02:28 PM
Will an AANJ Viper Neck work with 540R Body? Monsta-Tone All Other Guitars (including Prestige) 0 03-01-2012 10:57 AM
WTB: Saber Body (Square Heel for 22 fret neck) tienlo Classified Ads: Guitars and Gear 0 11-05-2010 08:29 AM
Ibanez PGM 30 body, Lo TRS trem, will a Lo Pro work on this body? born2liftanitowoc Tech: Setup, Repairs and Mods 1 07-21-2007 10:25 AM
