will a wizard neck fit a wizard II guitar? - Jemsite
post #1 of 7 (permalink) Old 01-28-2011, 12:01 PM Thread Starter
I have an RG470, and i have always wanted to have a crazy thin wizard neck on it. It has the wizard II, which is cool, but i love that yardstick feel that the 550 or 570 has!
My guitar has the AANJ. If i find a wizard neck that is also AANJ, will it fit alright? Keep in mind, my RG470 also has the LO TRS trem on it as opposed to the Edge/Lo Pro that the Wizard necks usually use.
thanks!
HumanFuseBen is offline
post #2 of 7 (permalink) Old 01-28-2011, 01:00 PM
Re: will a wizard neck fit a wizard II guitar?
You should also match up the country of manufacture. I dunno where the 470s were built, but korean and japanese necks are interchangeable where indonesian aren't.
If you have a korean or japanese guitar, a japanese neck will bolt on fine. You'll need to redrill the mounting holes for an indonesian neck however, and vice versa.
Number of frets also needs to match, so make sure you don't buy an S neck or something like that, as it won't intonate correctly.
GuitarBizarre is offline
post #3 of 7 (permalink) Old 01-28-2011, 01:04 PM
Reviews: 11
Sandpaper is your friend!
linuxpenguin is offline
post #4 of 7 (permalink) Old 01-28-2011, 01:29 PM Thread Starter
okay, mine is japanese. so, if i snag an AANJ 570 or 550 neck, it'll be alright?
thanks you guys!
post #5 of 7 (permalink) Old 01-28-2011, 01:38 PM
Yup, that'll fit fine.
post #6 of 7 (permalink) Old 01-30-2011, 06:13 PM
Go for it!
JoeRGSteve is offline
post #7 of 7 (permalink) Old 01-30-2011, 11:14 PM
RGTFanatic's Avatar
The Wizard and Wizard II are directly swapable provided the neck pockets are the same width. Ibanez has changed the width of both the original wizard and the wizard II throughout the years. You NEED to measure the width of your neck (in millimeters) and make sure that whatever your looking at to but is the same width. All other aspects of the two necks are directly replaceable with each other.
RGTFanatic is offline
ibanez , wizard , wizard ii
neck radius differences between the wizard and wizard II Robert tyler Tech: Setup, Repairs and Mods 5 12-28-2009 03:48 PM
Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck? Duck_man All Other Guitars (including Prestige) 10 08-19-2007 11:01 PM
neck shapes: Wizard vs. Wizard 7 MetalWarrior All Other Guitars (including Prestige) 0 11-08-2006 09:39 PM
Can a wizard II neck be sanded down to a wizard? Robert tyler Tech: Setup, Repairs and Mods 7 10-03-2004 02:51 AM
