Will this work? - Jemsite
post #1 of 5 (permalink) Old 03-27-2012, 01:16 AM Thread Starter
Reviews: 4
Will this work?
Hi,
All you tech guys. I need your help. I have an SV470, but the neck cracked bad, and I need a new one. It's not an Edge trem guitar, but a trem like a fender. It has a two screw trem that is made of solid brass. I can buy an S series Japanese neck with the same 22 frets, etc,. The only difference is that it has a Edge / Floyd Rose nut, and my old neck had a regular nut. But, I'm just wanting to buy a neck with the floyd nut / S series guitar neck and stick on this body, but I want to make sure it will work..
Will it intonate properly and work? I mean they are both the same scale length, etc? The only difference is maybe a little bit different radius, and the nut? Thanks in advance.. Let me know if it's work, or if I can just stick it on and intonate like a normal guitar neck attached to a body.. I want to just leave the neck trem nut on and use it instead of buying a new nut, but if a regular bone nut will work, please explain how to install if needs to be different? How to setup? I'm pretty handy with tools and stuff.. Used to work in a machine shop..
God speed
Tim
JustAGuitarDude is offline
post #2 of 5 (permalink) Old 03-27-2012, 05:33 AM
RGTFanatic's Avatar
Re: Will this work?
If the scale length and neck/pocket dimensions are the same then you should be good to go. The screw holes may not line up, but that's easy to retro-fit.
RGTFanatic is offline
post #3 of 5 (permalink) Old 03-27-2012, 12:03 PM
Dino's Avatar
Re: Will this work?
The neck pocket may be routed deeper on the SV. Do some measuring before you commit. Or just buy an S body and bridge, and transfer the other hardware and electronics.
Dino is offline
post #4 of 5 (permalink) Old 03-27-2012, 12:05 PM
Re: Will this work?
The nut will be fine. You might need to put a bit of foam under the strings behind it to stop any harmonic resonating. I have an RG480 neck here bolted to a cheap RG2EX1 body and it's one of my fav guitars. Had to put the foam behind the nut on this. You can see it on the right:
Mark_McQ is offline
post #5 of 5 (permalink) Old 03-28-2012, 01:39 AM Thread Starter
Reviews: 4
Re: Will this work?
Thank you guys so much. I think I'll work it out later. I'm in the process of aquiring a 90 540 S series.. Thanks
Tim
perle necks and bodies , rg neck , s neck
Will this work ? IbanezFreak777 Tech: Setup, Repairs and Mods 6 09-16-2011 09:19 PM
Anyone here work out? Necrojem Off-topic / Miscellaneous 103 06-10-2007 03:57 PM
my ada doesn't work the second eye Gear, Equipment, Recording & Off Topic 5 10-13-2003 07:41 PM
