Wiring help with RG - Jemsite
post #1 of 9 (permalink) Old 02-18-2011, 05:27 PM Thread Starter
Angry Wiring help with RG
I'm having a hell of a time wiring an RG. I have an old pup from and rg560 with 3 leads (red, white, ground) and in inf3 in the neck with 5 leads (red, white, blue, black, and ground). I am using a 3-way switch with 8 lugs. What goes where? I've tried this a million ways... Grrrrrrr!
thecrimsonrabbit is offline
post #2 of 9 (permalink) Old 02-18-2011, 11:43 PM
Reviews: 11
Re: Wiring help with RG
I will help you out when I get home, ok?
linuxpenguin is offline
post #3 of 9 (permalink) Old 02-19-2011, 10:18 AM Thread Starter
That would be great, thank you.
post #4 of 9 (permalink) Old 02-19-2011, 10:57 AM
Do you want the switch to select the pickups as follows?
1 - Neck pickup humbucking
2 - Neck and Bridge humbucking in parallel
3 - Bridge humbucking
This should work, ignore that it's a five way switch in the picture. Internally there is no difference. Actually, if you get the switch to stay in what would be the 2 and 4 position, you would get that signal. That's actually how the 5-way switch was born.
Match the colors as follows:
Picture vs Your pickups
Red - Blue
Black - White
Green - Black
White - Red
If someone can double check this for me, that'd be great.
xXLinkageXx is offline
post #5 of 9 (permalink) Old 02-19-2011, 11:13 AM
Go on the ibanez website USA go to the bottom click on support
click on wiring diagrams
The 2004 AT200 , should have the same or at least close wring (- 2nd pot) and should work
dragsternj is offline
post #6 of 9 (permalink) Old 02-19-2011, 04:37 PM
Reviews: 11
Linkage you are showing a wiring diagram for 4 conductor pickups dude.
Anyway, heres a sketch I made at work, should be correct.
edit : take a picture and show us where you are at if this doesnt answer your question
post #7 of 9 (permalink) Old 02-20-2011, 07:19 AM
Dude, read his original post again. He has 2 pickups and an 8 lug 3 way switch. And one of the pickups has 4 conductors.
post #8 of 9 (permalink) Old 02-20-2011, 12:44 PM
Reviews: 11
Oh shoot my bad man lol. I just remembered my struggles wiring were always the 3 wired humbuckers, because I always thought the white wire was a ground and I spent HOURS fiddling with it. lol I didnt even see the second humbucker had 3 wires on your diagram either lol... Imma go sit in the corner for 5 minutes
post #9 of 9 (permalink) Old 02-22-2011, 09:02 AM
So, I guess not even a thank you from op. With 6 posts in 3 years, we probably shouldn't expect one.
wiring rg
Ibanez Wiring vs. DiMarzio Wiring HSH MattPM Pickups & wiring 34 06-06-2012 03:49 PM
JS1 ('90/'91) Volume Pot Wiring / Wiring Model? guitarboy Ibanez JEM, UV, JS & Other Signature Models 0 01-14-2007 04:31 AM
Bad wiring on UV JN777 Pickups & wiring 1 04-14-2005 10:41 PM
Re-Wiring Question - Ha, semi-related to the "Wiring Questio Two hands31 Tech: Setup, Repairs and Mods 19 01-03-2002 06:26 PM
WIRING HELP NEEDED - wiring on RG aerocol Tech: Setup, Repairs and Mods 6 07-17-2001 01:02 PM
