Wzard neck on an RG321 body - Jemsite
post #1 of 18 (permalink) Old 05-02-2008, 06:38 PM Thread Starter
Will a Wizard neck from an RG570 fit on an RG321 body without any mods? Just curious, I'm thinking of taking on a project. Also, would a standard fixed Strat-style bridge fit on the RG321 body?
Thanks,
Chuck
cjl5150 is offline
post #2 of 18 (permalink) Old 05-02-2008, 07:03 PM
Ayrton's Avatar
Re: Wzard neck on an RG321 body
The 570 neck may be a bit thinner (width), but is should bolt up fine provided they have the same neck joint style (AANJ)
Ayrton is offline
post #3 of 18 (permalink) Old 05-02-2008, 07:35 PM
Reviews: 6
Tell us if it works.
PrinceAlice is offline
post #4 of 18 (permalink) Old 05-02-2008, 07:44 PM
nothing wrong with the locking nut ?
Agent540 is offline
post #5 of 18 (permalink) Old 05-02-2008, 08:12 PM
It won't work I've tried it.
D.Vial is offline
post #6 of 18 (permalink) Old 05-02-2008, 08:27 PM Thread Starter
So, the Wizard isn't a direct replacement for the Wizard II???
cjl5150 is offline
post #7 of 18 (permalink) Old 05-02-2008, 08:29 PM Thread Starter
Was the neck that you used an AANJ?
cjl5150 is offline
post #8 of 18 (permalink) Old 05-02-2008, 08:55 PM
Yes it was, in fact it was a Wizard II
D.Vial is offline
post #9 of 18 (permalink) Old 05-02-2008, 10:12 PM
There may be a problem with the location of the screw holes. Any decent luthier could dowel and re-drill as needed.
albee1952 is offline
post #10 of 18 (permalink) Old 05-02-2008, 10:59 PM Thread Starter
Well, I just took the neck off of my favorite guitar, an RG570, and tried putting it on the 321 and that is the problem-the location of the the screw holes. The neck fits in the pocket just fine. I'm wondering if I do dowel and redrill-will the scale length be off and cause an intonation problem? FWIW the neck looks great on the body, it's one of the flame top, redburst ones. I really want a hardtail RG with a Wizard neck.
cjl5150 is offline
post #11 of 18 (permalink) Old 05-02-2008, 11:01 PM Thread Starter
What kind of problems did you have?
cjl5150 is offline
post #12 of 18 (permalink) Old 05-02-2008, 11:31 PM
Ayrton's Avatar
Just drill new holes and dowel the old ones.
You will not have any scale problems, because both guitars are the same scale.
Ayrton is offline
post #13 of 18 (permalink) Old 05-03-2008, 12:08 AM Thread Starter
Good point. I was just thinking that the neck pocket seems to go further into the body on the 570 versus the 321.
cjl5150 is offline
post #14 of 18 (permalink) Old 05-03-2008, 12:58 AM
Just measure from the bridge to the 12th fret and to the nut.
Darin is offline
post #15 of 18 (permalink) Old 05-03-2008, 10:25 PM
The Wizard II was from a tremolo-equipped guitar so it was a bit thinner (width) and a considerable space of the joint was left over from the left side.
D.Vial is offline
equipped guitar , locking nut , neck joint , paf pro
Warped neck? Cracked body? help me out! Devon8822 Tech: Setup, Repairs and Mods 15 10-21-2007 06:26 PM
FS: AT300, RG7620VK body and neck ajdehoogh Classified Ads: Guitars and Gear 5 07-21-2007 08:55 PM
Check this out!!!!! ELicari Ibanez JEM, UV, JS & Other Signature Models 73 08-28-2006 10:09 AM
Epihone neck on an Ibanez body? jonadam1975 All Other Guitars (including Prestige) 7 07-12-2005 04:08 PM
RG450DX Complete Body and Neck Parts TAorama Classified Ads: Guitars and Gear 6 06-19-2005 10:20 PM
