XL neck question.... - Jemsite
post #1 of 8 (permalink) Old 08-03-2003, 04:27 AM Thread Starter
On a 7 string XL neck, can you tune it to (A,E,A,D,G,B,E), the stock Ibanez tuning is a step below (A,D,G,C,F,A,D) and i've tried tuning it to (A,E,A,D,G,B,E) but the bridge seems to rise pretty high. So is it possible to tune an XL neck to that tuning? I use a 2077XL by the way. Thanks
nosferatu123 is offline
post #2 of 8 (permalink) Old 08-03-2003, 10:26 AM
Yes, you can, you just have to adjust the bridge. You can basically tune it to whatever you want until you can no longer adjust the bridge, or you break a string, whichever comes first.
Two hands31 is offline
post #3 of 8 (permalink) Old 08-03-2003, 02:00 PM
I play the 7421XL. It's a fixed bridge, and I have no experience with the trem models, but I have mine tuned A-E-A-D-G-B-E using 11's and a 72 for the low A. I've had no problems with it.
Jim Soloway is offline
post #4 of 8 (permalink) Old 08-03-2003, 04:04 PM
I have a RG1077XL with .10's tuned to D (7th is a .60)...feels great. For standard tuning I'd personally use .09's
caprile is offline
post #5 of 8 (permalink) Old 08-03-2003, 06:04 PM
I add another spring to my 1077XL, and tune it standard (B,E,A,D,G,B,E) and use 10-60 strings...never had a problem with the bridge. Quite comfy.
Akhenaten is offline
post #6 of 8 (permalink) Old 08-03-2003, 10:21 PM Thread Starter
I notice many of yall here are using .10's , but the gauge i use is a .09, will it be possible to tune to AEADGBE or do i have to get a .10 too?
post #7 of 8 (permalink) Old 08-03-2003, 10:39 PM
no problem....just adjust the tremolo springs so the trem angle is right
caprile is offline
post #8 of 8 (permalink) Old 08-13-2003, 01:53 AM
I used mine and my other 7 strings in standard tuning and I used 10's nad on one of my guitars, I have 11's
Some guys don't hear the difference between a floppy string and a taught one. The best reason for using 10's or even 11's is not tonal, but the better tension.
You'll notice that on crappy 5 string basses, the low B strings sound terrible and lack definition.Many of the better, more expensive basses have better electronics and construction that allows for more proper tension.You can use any strings that you like but 10's are going to get your low strings to sound more defined as opposed to thin strings.
BUt a 7620. or 1077 or 2077 should be able to accomodate all of the above tunings without any problem
Paul Secondino is offline
fixed bridge , low strings , string bass
Nooby Question: Cleaning the neck (not fretboard, neck!) mango_icecream Tech: Setup, Repairs and Mods 8 05-12-2008 10:03 PM
question about neck j45m16 Ibanez JEM, UV, JS & Other Signature Models 10 06-11-2007 05:10 PM
NECK QUESTION. (sorry) FRETPICK All Other Guitars (including Prestige) 18 08-08-2006 09:56 AM
another neck question ---> sticky neck spacenuke Tech: Setup, Repairs and Mods 9 11-12-2002 11:45 AM
BSB Question - neck finish question j i m Ibanez JEM, UV, JS & Other Signature Models 7 02-23-2001 06:29 PM
