ZR direct replacement arm holder - Jemsite
post #1 of 4 (permalink) Old 09-27-2007, 06:37 PM Thread Starter
Having a guy build me these for my ZR equipped guitars. They are machined out of brass and won't rust and are a direct replacement for the ZR arm holder. Are made to accept the lo-pro trem arms.
lcsdds is offline
post #2 of 4 (permalink) Old 09-27-2007, 06:53 PM
Re: ZR direct replacement arm holder
I thought the regular Lo Pro holder was a match? Now if he'd make original ZR2-9 replacement holders out of steel he'd have something there!
Rich is offline
post #3 of 4 (permalink) Old 09-27-2007, 07:19 PM Thread Starter
The lo-pro works but it isn't a "match". You have to use a nut and a washer on the backside and the nut is like a custom nut that you can't just buy anywhere that I have found. These will have the flats machined into them so you just drop them in and put a nut on the backside and you are good to go. These can be made out of steel if you want.
lcsdds is offline
post #4 of 4 (permalink) Old 10-03-2007, 07:22 PM Thread Starter
finished product. Accepts lo-pro pop-in style arm.
lcsdds is offline
arm holder , equipped guitar , trem arm , trem arms
Replacement of your trem arm - "tutorial" with pictures Jammy Tech: Setup, Repairs and Mods 94 02-15-2012 04:40 AM
sr505 direct replacement pickups and bridge id Pickups & wiring 11 07-27-2010 03:52 PM
What multi effect to use direct to mixer PA? DotNetTim Gear, Equipment, Recording & Off Topic 13 05-21-2005 01:48 AM
Is the Lo-Pro a direct replacement for the Edge cavity wise? dacmo Archived Topics and Common Questions 11 02-02-2004 02:35 PM
Is the Lo-Pro a direct replacement for the Edge cavity wise? dacmo Tech: Setup, Repairs and Mods 7 04-04-2001 02:37 AM
