[HELP] FRET BUZZ - Jemsite
post #1 of 9 (permalink) Old 07-25-2011, 01:02 PM Thread Starter
[HELP] FRET BUZZ
Hello Guys
I have a fixed bridge guitar with 22 frets (OLP MM1)... it has a very annoying fret buzz on 3rd up to the 9th fret ( E A D strings ) I want to fix the fret buzz while having an action of 1.5mm-1.8mm... BTW it started more than a week ago when i change the saddles,replace it to a new one(same type of saddle before) and also replacing the old string.. the intonation was fine, and the only problem is the fret buzz.
Hope you guys could help me//
renzcastle is offline
post #2 of 9 (permalink) Old 07-25-2011, 03:13 PM
Re: [HELP] FRET BUZZ
Same type of strings you've been using? Lighter strings often have more buzz. D'Addario also seems to be made out of a very springy steel now and rattle more than I like.
gideond is offline
post #3 of 9 (permalink) Old 07-25-2011, 03:30 PM
Reviews: 98
What gauge strings are you using? Do you have the OLP MM1-F with the Floyd, or the non-locking trem? If you have the Floyd equipped version, you may want to put some very thin shim under the locknut on the treble side to eliminate the buzz. If you have the non-locking trem, take a look at the net slots--you may need to clean the grooves a bit.
Saddle shim is another possibility.
AlaskaBat is offline
post #4 of 9 (permalink) Old 07-25-2011, 03:53 PM
He did say fixed bridge AlaskaBat, though you did answer both anyway.
Ibateur is offline
post #5 of 9 (permalink) Old 07-25-2011, 04:17 PM
Reviews: 98
As usual, I didn't even see that part. But yeah--I answered in a fashion that would help any other members with a similar situation.
post #6 of 9 (permalink) Old 07-26-2011, 02:07 AM Thread Starter
thnx for the answer guys... im using the same gauge (9-42 D'addario string)
I have another question... is it normal when the distance of the string on the 12th fret and the string (lower E) is about 1.5mm while on the first fret,the distance from the fret and the string is less than 1mm?
post #7 of 9 (permalink) Old 07-26-2011, 02:23 AM
Reviews: 98
Yes--the string height increases slightly from the nut to the bridge.
post #8 of 9 (permalink) Old 07-26-2011, 02:38 AM Thread Starter
and additional info the relief is almost zero there is no enough clearance on the 7th fret while fretting the 1st and last fret
post #9 of 9 (permalink) Old 07-26-2011, 09:08 AM
Loosen the truss rod about a 1/4 turn. Some people say that an Ibanez neck can be perfectly straight but I haven't seen one yet that doesn't need at least a little relief.
gideond is offline
fret buzz
Got a new guitar, but its got fret buzz on one string at one fret how to fix? ibanezcollector Tech: Setup, Repairs and Mods 6 11-25-2006 06:43 PM
Fret buzz on 13th fret AleTheNervo Tech: Setup, Repairs and Mods 1 04-19-2006 07:49 PM
fret buzz - above 12th fret nat1201 Tech: Setup, Repairs and Mods 6 04-11-2002 12:29 AM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
Strange fret buzz - Only at 16th fret, G string carlos seo Tech: Setup, Repairs and Mods 3 02-06-2001 11:12 PM
