2 tech type questions - Jemsite
post #1 of 5 (permalink) Old 02-19-2012, 07:43 AM Thread Starter
Hi guys,
I've got 2 quick questions for ya:
Ive just bought a new lo pro edge kit. The body inserts for the trem posts - what do you guys do - just push it into the holes or should one use superglue/araldite in there just to secure it in place?
The holes in the rear trem cavity - are the holes for the screws for the spring claw drilled in parallel with the body or at an angle? (or does it not matter?)
Thanks
hangingmonkey is offline
post #2 of 5 (permalink) Old 02-22-2012, 05:32 AM Thread Starter
Re: 2 tech type questions
Bump
...anyone...
question 2 above is no longer an issue, just wondering what people do re question 1
post #3 of 5 (permalink) Old 02-22-2012, 10:40 AM
Well, providing the holes are the correct size to fit the insert, yes, you can just press them in. They have to be snug though otherwise they'll work their way out. So if they go in fairly easy, they should be glued a tad bit.
TMatt142 is offline
post #4 of 5 (permalink) Old 02-22-2012, 11:01 AM
Never drilled the holes for the string claw, but the stud inserts are just pressed in. That said, I'd rather be safe than sorry so after pressing them in I'd prefer to hit it with thin super glue, which should wick right in there.
Takin' a Ride is offline
post #5 of 5 (permalink) Old 02-22-2012, 12:14 PM
holes are probably at a slight angle. IN the mod arena, when installing the trem claw, I used a 8" long extension bit to drill the holes, and the angle was probably in the 10ish degrees range.
andrewgosline is offline
inserts , post , trem
Tech Box Professional guitar tech station rikkbeatty Classified Ads: Guitars and Gear 2 09-17-2011 04:36 AM
Some Noob-Type Tube Amp Questions Big Red Gear, Equipment, Recording & Off Topic 2 10-11-2007 12:43 PM
Cab questions, open back, close back, speaker type... Rotti Gear, Equipment, Recording & Off Topic 0 06-20-2007 07:40 PM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman Ibanez JEM, UV, JS & Other Signature Models 6 09-08-2001 02:10 PM
Guitar Tech in Chicago - Guitar tech with experience in Jem Vai Halen Tech: Setup, Repairs and Mods 1 02-22-2001 09:38 PM
