4/5 Strings in stock original edge block? - Jemsite
post #1 of 3 (permalink) Old 12-10-2015, 01:47 PM Thread Starter
So I've decided to put heavier strings on one of my guitars, but I'll need an extra spring under the hood. Has anyone here succeeded in putting more springs in an original edge block? I ask because instead of having five holes for springs, two of them are screw holes for the spring retainer (which is not in). I don't want to be playing and all of a sudden have a spring come out from the block.
^Not my picture, but you can see what I mean with the screw holes between the center and size spring holes.
Damn... Just realized title says strings... I meant 4/5 springs.
accidental is offline
post #2 of 3 (permalink) Old 01-04-2016, 01:18 PM
Re: 4/5 Strings in stock original edge block?
I did this a while back with my Edge Pro 7 when i went from 9's to 10's i realized i needed more spring tension to get the right trem angle, i remove the retainer and put one more spring, obviously i could not put the spring retainer back, i went back to 9s some time after and removed the extra spring but it worked fine for the time i played 10's.
Rafafas is offline
post #3 of 3 (permalink) Old 01-04-2016, 08:49 PM Thread Starter
Yeah, I did it while running 10.5s for a while but after two weeks just went back to 10s as a like them better. It worked at least.
ibanez , original edge , spring
Question about upgrade brass sustain block for Original Edge leathermonkey7 Gear, Equipment, Recording & Off Topic 2 04-01-2012 11:13 PM
Original Edge Trem - Replace the block? kigorri Tech: Setup, Repairs and Mods 4 08-19-2009 12:50 AM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 08:19 PM
WTB/WTT: Cosmo EDGE Pro wanted, can offer cosmo original EDGE with HS block for trade gitarrero Classified Ads: Guitars and Gear 1 04-01-2008 07:51 AM
For Trade: 31mm Edge spring block for 41mm block mtxsho93 Classified Ads: Guitars and Gear 0 04-02-2007 05:29 PM
