5-Way Switch for Ibanez HH - Jemsite
post #1 of 10 (permalink) Old 10-18-2018, 01:03 PM Thread Starter
A friend dropped off an RGA121 for me to refret and do some general fixing. The pickup switch is really mangled, loose, and crackly so I'm thinking it needs to be replaced. However I have read in the past that Ibanez 5-way switches are not the standard kind, which is how they achieve this functionality:
1-neck series
2-neck parallel
3-neck in series, bridge in series, pickups in parallel
4-1 coil from each pickup in parallel
5-bridge series
(I can't post an image or link to the pickup switch functionality for some reason)
So I'm wondering, where can I get a replacement switch? And if possible, are there any switch options out there that are more mechanically durable than the stock switch? It reminds me of the type that would come in a MIM fender or a squier, not like a mechanical CRL or Switchcraft switch which I prefer to use.
davegardner0 is offline
post #2 of 10 (permalink) Old 10-18-2018, 01:31 PM
It's called a superswitch, do a search on the bay and you'll find dozens, don't bother with the US stuff, it's not metric and won't fit properly.
sepulchrave is offline
post #3 of 10 (permalink) Old 10-18-2018, 07:22 PM
Reviews: 120
Re: 5-Way Switch for Ibanez HH
Ibanez had switches made by Cortek for this specific function, they, re not the super switches. The model is 3PS1SC5 from memory
LonePhantom is offline
post #4 of 10 (permalink) Old 10-19-2018, 10:40 AM Thread Starter
I think this is just what I need. I noticed the actual switch inside the guitar says "2502N", is that the same thing? A quick internet search seems to suggest yes but I'm unsure.
post #5 of 10 (permalink) Old 10-20-2018, 02:11 PM Thread Starter
Looks like the Stew-Mac Oak-Grigsby super switch will fit. I found a wiring diagram for it on youtube as well (can't post links?) so I'm going to go with that. Thanks for the help!
post #6 of 10 (permalink) Old 10-20-2018, 03:38 PM
The mounting hole centres won't match, they're not metric. I did mention this earlier.
post #7 of 10 (permalink) Old 10-21-2018, 10:43 PM
Reviews: 120
Yes that's it from memory
post #8 of 10 (permalink) Old 10-22-2018, 06:05 PM Thread Starter
I don't think that's true. I just double checked my measurement, the mounting holes centers are exactly 1 5/8" apart, which is exactly what Stew Mac says the switch is. I ordered it so we'll see when it arrives.
post #9 of 10 (permalink) Old 10-25-2018, 05:35 PM Thread Starter
Ok I received the Stew-Mac switch and I can confirm it fits perfectly into the RGA121. The mounting holes definitely line up and the switch (barely) fits into the control cavity depth-wise.
post #10 of 10 (permalink) Old 10-29-2018, 09:42 AM Thread Starter
I wired this up over the weekend using the Stew-Mac superswitch. Lots of connections on the switch! But it works well and now the guitar has a much better switching feel IMO.
Wiring Diagram I came up with (switch needs to be turned 180 degrees in the guitar fyi)
rga121 , switch
Prestige Ibanez HH (RGT220) 5-way switch wiring help Octoberine All Other Guitars (including Prestige) 1 06-10-2017 02:16 PM
3 Way Switch vs 5 Way Switch Sean777 All Other Guitars (including Prestige) 6 07-23-2013 11:53 PM
Quesiton about corresponding ibanez 5 way switch diagrams for a fender 5 way switch GuitarEvan07 Tech: Setup, Repairs and Mods 0 06-19-2009 09:20 PM
HH Emgs with Ibanez Cor-Tek 5 way switch Bytrix Pickups & wiring 0 03-03-2009 05:27 AM
2 Humbucker HH and Ibanez 5 way switch Brando Clean Pickups & wiring 15 11-27-2007 03:30 AM
