94 Jem 555 locking nut questing help - Jemsite
post #1 of 4 (permalink) Old 01-24-2019, 06:57 PM Thread Starter
I’m trying to replace the hardware of my 94 Korean 555 but there’s no information On any spec sheet I can find that tells what size the locking nuts are? I see 43mm for RG and Japan guitars... is it the same? What are the numbers (43mm 15mm) I should look for to replace these to match the size of my old ones? Is it Floyd that’s on it? Gotoh? Ibanez? Anyone know the tuner size too?
Jamesalister is offline
post #2 of 4 (permalink) Old 01-24-2019, 07:54 PM
43mm locknut, 17" radius fretboard, LoTRS2 tremolo, Gotoh style tuners M10 135.
However in your situation your top priority should be replacing the tremolo with a quality unit, tuners don't matter and the locknut either works or it doesn't.
sepulchrave is offline
post #3 of 4 (permalink) Old 01-24-2019, 08:27 PM Thread Starter
Thanks man, I found a site that has lo pros and edge and edge pro for under $250 new.. just have to figure out if all those will drop in without modifying the cavity?
post #4 of 4 (permalink) Old 01-24-2019, 09:06 PM
The cavity on the Jem is huge due to the lions claw rout, any of them should fit easily, however you will need to bore out the stud anchor holes if you want to use the locking studs supplied with the Edge/Lopro.
FS: Ibanez/Gotoh Chrome Locking Nut & Magnum Locking Machine Heads Japanese JEM Or RG lewis.mann Classified Ads: Guitars and Gear 1 05-15-2009 03:06 AM
Locking Nut vs. Locking Tuners ryanb Tech: Setup, Repairs and Mods 11 03-30-2006 12:03 AM
Modding a Non-Locking neck to fit a Locking nut? ZOMB13 Tech: Setup, Repairs and Mods 21 07-04-2005 07:11 PM
JEM 555 Quality - quality issues with the jem 555 kylemac Ibanez JEM, UV, JS & Other Signature Models 3 07-26-2001 01:13 AM
Sperzel locking tuners & non-locking nut - for a fixed bridg jemsite Tech: Setup, Repairs and Mods 9 03-22-2001 11:51 PM
