Is the 9V battery fits under 7VWH or RG550 pickguard? - Jemsite
post #1 of 4 (permalink) Old 04-27-2004, 01:30 PM Thread Starter
I am looking for a player 7VWH to modify with EMG pickups and a new finish. I am wondering if there is enough space in the control route of the body to put the 9V battery. I don't want to drill the hole in the guitar. Any suggestion? Thanks in advance guys.
cocobig is offline
post #2 of 4 (permalink) Old 04-27-2004, 01:33 PM
I have a 550 with EMGs and a small section of wood was removed between the jack socket route and the main controls route to accomodate the battery. I think, after having a root round in there that it could fit *just* without any mods, and with some carful placement.
Jammy is offline
post #3 of 4 (permalink) Old 04-28-2004, 02:25 AM
i once installed a set of EMG in a 550Ltd, and i didnt rout anything to fit the battery into the cavity.
nuno is offline
post #4 of 4 (permalink) Old 04-28-2004, 01:08 PM
You can usually get a battery vertically between the 5-way switch and the volume knob. Especially when they give you the smaller diameter pots with the EMG's. Otherwise horizontally it should fit under the volume knob area. In that case, sometimes it's better to put the battery in first with double stick tape, then put the pickguard down over it.
frankfalbo is offline
jack socket
FS: Clear pickguard, fits RG550 and a bunch of others Jason2112 Classified Ads: Guitars and Gear 1 05-14-2011 03:36 AM
FS Pearloid Pickguard - Fits JEM/350/550/750 madpickin03 Classified Ads: Guitars and Gear 8 05-26-2009 01:19 PM
Which pickguard fits on an RG470? Ad_Astra Tech: Setup, Repairs and Mods 6 04-02-2008 04:40 AM
What pickguard fits? Speedica All Other Guitars (including Prestige) 4 11-09-2005 08:04 AM
JEM7VWH pickguard fits JEM555WH??? - just wonder truenobzr Ibanez JEM, UV, JS & Other Signature Models 5 03-20-2002 11:23 PM
