AANJ conversion on UV neck - has anyone tried it? Is it hard - Jemsite
post #1 of 3 (permalink) Old 08-30-2001, 10:50 AM Thread Starter
Another step towards starting up my little project (a description of it is floating around somewhere on the forum) is deciding wether I want to stick with the standard bolt on neck or go with an AANJ. It is sort of a step I have to decide on now rather than later so I can start planning everything out properly...
The problem I have is that I have an old-style bolt on universe neck that is to be used for this project (of a UV7BK), so If i am to get an AANJ body, then I am going to need to do a neck conversion on it (or have it done by someone else).
So is this hard to do? What are the problems associated with doing it? Has anyone done it/attempted to do it? Has anyone done it on a UV neck? If the conversion is done, how can you tell it matches a AANJ (The reason I am asking this is because I want to order a body from custom guitar wares, but don't really want to ship the neck there and back (customs and all that, and expense, and risk of losing it))?
And finally...if I decide it's too risky for me to do (I would prefer not to screw it up...) is there anyone out there who feels comfortable/confident enough to do it? (Of course for some form of reimbursement for effort (also known as money))
James
7 Dying Trees is offline
post #2 of 3 (permalink) Old 08-31-2001, 06:44 PM
Hi James
I have done this type of convertion on a standard 6 string neck and if your going to do it your really going to want to have the neck finished and sent in to make the pocket on the body.
Your kind of in a catch 22 though, let me explain......
The first thing you need to do is to add a block of wood to the neck under the fret board where it extends at frets 22-24 since every AANJ body I have ever seen has the neck pocket going right up to the neck humbucker cavity.
Then of course you need to shave and re-contour the top of the heal on the back of the neck to conform to the shape of the body. which is kind of hard to do without the body being present, see what I mean?
Peace, Brian
Project Guitar is offline
post #3 of 3 (permalink) Old 11-10-2012, 04:44 AM
Re: AANJ conversion on UV neck - has anyone tried it? Is it hard
I'm doing a DIY on a JEM since I don't seem to have $1,000's of dollars in my back pocket!! Not trying to sound holier than thou but I know I can do this as a G.I.T. grad (89). So I've held a few guitars. So I bought a beautiful JEM neck ,but it has close to a square neck? There is a slight 5/8ths" curve on the end but of course it's under the last 4 scalloped frets which part of will need to be removed for the overhang.
Over the years I've supplemented my income and became a pretty good carpenter,but I'm a bit perplexed as to the challenge of the AANJ? I guess I can blow up a photo to copy? Once I get the overhang done (I'm thinking table saw with a new blade to avoid splintering the wood). Then hopefully get a snug fit trace the curve with a pencil then getting it close with a steady dremel ,NOT TO CLOSE! I can finish starting with 80-100 grit and work up to 360-400 grit maybe wet sanding? Been awhile,I can't remember it wet sanding entails wd-40? Or if I can use a drop or two of h20? If it's the latter the yea. Any one out there have a more ...safe process? LOL!!!! THANKS.
Can't upload a simple PHOTO!!!!!
VAIHALENSURF is offline
custom guitar , custom guitar wares , fret board , neck finish , neck humbucker
RG neck block to AANJ conversion? AKMG Tech: Setup, Repairs and Mods 24 07-15-2006 04:09 PM
fs custom hard tail conversion gunkungfu Classified Ads: Guitars and Gear 4 08-27-2005 12:51 PM
Kramer Sustainer... - How hard would it be to make an AANJ o dwswift Tech: Setup, Repairs and Mods 8 04-09-2001 07:47 PM
