Acoustic pickup in a solidbody neck pup spot - Jemsite
post #1 of 3 (permalink) Old 01-01-2001, 10:14 AM Thread Starter
As some of you may know, for quite some time now (not as long as it took Tommy to get his custom neck though) I've been fumbling with an old Radius 540HH.
I thought about the pickups to put in it and would like a piezo system. *In my vast creativity, I brainstormed the idea of putting a usually-sound-hole-mounted acoustic pickup into the neck position on the guitar (and a regular pup in the bridge). *Probably would mount it on top of the pup cavity, or route a space so it's flush to the body. *I'll probably just tung the body then. *Im not a guitar luthier though, and am not aware of any intracasies I might run into, since I haven't field tested the idea in a local store.
Anyone got any thoughts? *possible problems?
tomizm is offline
post #2 of 3 (permalink) Old 01-01-2001, 10:47 AM
Sounds like a worth wild plan. Or you could try to use a mini mic.
Noodles is offline
post #3 of 3 (permalink) Old 01-01-2001, 01:00 PM Thread Starter
Mini Mic? *What is it?
tomizm is offline
neck position , piezo system
Spot on RG550 neck moonlight Tech: Setup, Repairs and Mods 10 06-05-2009 02:12 AM
Samick D7 solidbody acoustic, rosewood back and sides, cedar top, grover tuners! lordoftheparty69 Classified Ads: Guitars and Gear 0 01-02-2007 06:43 PM
the breed neck model in the bridge spot? Roadstar Pickups & wiring 12 10-06-2005 01:21 AM
Acoustic guitar pickup question little wing All Other Guitars (including Prestige) 4 03-09-2004 04:20 AM
Acoustic pickup for ericbrowning Gear, Equipment, Recording & Off Topic 1 11-04-2001 08:38 AM
