Add a low/half power mode to the power stage - Jemsite
post #1 of 4 (permalink) Old 09-29-2006, 04:57 AM Thread Starter
Hi,
I'm looking for a new amp, but I'm frustrated about the fact that a lot off good sounding higher pricerange amps lack a switch to put the power amp in a lower power output mode. (I have my eye on a Hughes & Kettner Switchblade 100watt top/combo or JSX. the jsx combo has a half power switch, the top doesn't :/).
So I was wondering if it's possible to add this kind of feature to an amp ? A guy on HC told in his review of a Peavey classic stereo 19" poweramp he just removed some of the EL84 (4 per channel) to use it at low power. (Is that a good idea anyway ?).
Thx
Silverburst is offline
post #2 of 4 (permalink) Old 10-03-2006, 09:58 AM
Re: Add a low/half power mode to the power stage
It is possible for you to do it yourself, if you are somewhat knowledgeable on electronics and have point to point wired amp, it would be quite easy to put pentode-triode switch. But if you are not, it is possible to halve the output by taking simply half of the tubes out. Be sure to take them off in pairs, ie. outer pair or inner pair.
Hope this helps
morgtahna is offline
post #3 of 4 (permalink) Old 10-03-2006, 07:50 PM Thread Starter
thx for the reply. ah okay... I wasn't sure just removing tubes was possible, since tube amps can be pretty sensitive to load attached etc, I was guessing it could not be just as simple as removing a pair.
I hope to learn more about amp electronics, but atm, I'm far too rookie to start fiddling around with a high end amp without guidance hehe.
post #4 of 4 (permalink) Old 10-03-2006, 08:51 PM
Hope this helps
Possibly worth emailing the service department of the company who made your power amp and confirming that removong two tubes is okay - they'll probably advise you of which tthe best two to remove are anyway.
Cheers
David
David McCarroll is offline
jsx combo , kettner switchblade , peavey classic , power amp , tube amp , tube amps
Phantom Power Ant1981 Gear, Equipment, Recording & Off Topic 13 03-15-2006 01:22 PM
vht pitbull 100cl vs the UL and clx texshred777 Gear, Equipment, Recording & Off Topic 25 01-30-2003 02:08 AM
Preamps Vaiworship Gear, Equipment, Recording & Off Topic 5 11-01-2001 08:49 AM
AMP POWER - significance of watts mmr7 Tech: Setup, Repairs and Mods 15 08-25-2001 08:49 AM
