Adjusting string height TAT SPECIAL CL14 SCHALLER TREMOLO - Jemsite
post #1 of 2 (permalink) Old 01-25-2017, 07:32 AM Thread Starter
Hi, i recently bought a TAT SPECIAL CL 14... the action its pretty low, and while its ultra comfortable to play, which i love, it buzzes to the point of totally muting the strings while using the tremolo bar for a wide vibrato, which i dont like. So, i figured i need to adjust the action and keep the strings a bit higher. Here is my doubt: Some say i only have to just rotate the pivots at the side of the bridge till the desired string height, but others say that this method will deteriorate the knife edges, affecting tuning stability, among other problems, and that i should take the tremolo off the guitar to do such adjustment. I also have read that this tremolo ( a floating schaller) being a high end tremolo (similar to the original floyd rose in terms of quality), wont sustain any noticeable damage , compared to a cheap licensed tremolo, if do the adjustment the "easy"fast" way i mentioned.
Hope you can help me.
ElMadera is offline
post #2 of 2 (permalink) Old 01-25-2017, 07:51 AM
Re: Adjusting string height TAT SPECIAL CL14 SCHALLER TREMOLO
two things
1. maybe you should check neck to body angle and correct it with shim,
2. regarding tremolo height from:
http://www.jemsite.com/forums/f16/do...ge-135572.html
This is just my advice. Read my and other posts and decide yourself.
I would never change bridge height on full tension.
First of all, regarding height of tremolo, if you want to play fast you need some resistance from guitar.
You will play faster in medium high action then on (silly) low action. You need strings to fight back. If action is to low when you play very fast, like Vai or Malmsteen, to low action make strings become to soft. This is in case if you pick, but if your playing techniques like Stanley Jordan who exclusively taping on neck with no picking, then you need action low as you can achieve. That are two extremes, Tosin Abasi is probably in the middle.
Regarding changing bridge height on full tension,
if knife edge is proper condition, then you have ONE returning point,
so if You push bar down or pull up it will go back in same returning point,
and guitar will be always in tune.
If you have damaged knife edge, your returning point will split in TWO returning points, when you push bar down bridge will go back in lower returning point,
if you pull it up, it will return in higher returning point. It is not end of the world, and lot of guitars are perfectly playable in that condition, because you will tune it to one point and always return it to that point. Pro players are doing that all times.
This sound complicated but it is not. If you tune it in higher resting point, if you pull bar up it will return to higher resting point, and you do not have problem, if you push bar down you will not just let it rest on lower resting point, you will either on way back raise it slightly to jump to come back in upper resting point or put it in upper resting point by bending strings. If you do it few times deliberately, soon it will natural to you.
On quality bridges knife edge is very hard, so you can change bridge height on full tension few times without damage,
on softer bridges knife edge will be damaged faster if you change bridge height on full tension ,
and on too soft bridges, knife edge will be damaged with just regular use, even if you change action without tension.
Some players are using lipstick balm or similar as grease in place where posts and knife edges have contact.
Again, to claim no damage on rotating metal rod against sharp knife edge on full tension is er.. stupid.
People for centuries sharpen their knifes with piece of metal pressing(that is tension) against knife edge.
peromucho7 is offline
string action
Necessary to de-tune/relieve string tension before adjusting action on tremolo guitar abstract_noise Tech: Setup, Repairs and Mods 5 04-03-2014 05:56 PM
Adjusting the height of Jem Breeds chazfest Pickups & wiring 3 09-13-2008 09:43 AM
Adjusting Pickup Height Screaming Solo Pickups & wiring 6 01-28-2006 03:37 PM
Can you individually adjust the height of a string on a Lo Pro and Edge tremolo? Econ Tech: Setup, Repairs and Mods 4 12-13-2005 08:26 PM
pickup height - adjusting sevens Tech: Setup, Repairs and Mods 4 01-29-2001 03:38 AM
