advice needed for a edge pro bridge - Jemsite
post #1 of 3 (permalink) Old 11-23-2015, 09:19 AM Thread Starter
i wanted to restring my guitar . i bought a new jem recently
it came with new strings from the shop i bought it.
i am familiar with floyd rose . but somethings on the jem are new to me
and the manual doesn't really cover my question.
if i look at bottom side of the edge pro bridge each string has an red saddle/cover with a screw . it seems the string bullets are seated there.
as i check the manual it talks about cutting the bullets at the end off.
so my question is . whats the difference with these saddles or restringing the guitar with cutting off the bullets.
and will i notice any difference between the two manners of restringing.
my local store says to cut them off . but in my opinion does saddles are there for a reason so why cut them off.
and what is the best way to mount the string with those red saddles as it seems the space to manouver is very small.
thanks in advance
Jeremy
jvharskamp is offline
post #2 of 3 (permalink) Old 11-23-2015, 09:30 AM
Re: advice needed for a edge pro bridge
Its down to personal preference as to what you do. I have the same on my js, i leave the ball ends on the strings and push them in to the red covers so that the ball rests in the curve at the bottom, they dont have to be orientated in any way.
I believe this was added because people whinged that they had to cut the ball ends off, i have guitars with both types of trem and neither present a problem to me. the only advantage i can see is when a string breaks during a gig and you no longer need to cut the ball end off (the other soloution to this is to feed the string through with the ball end at the tuner).
It can be a pain getting the strings out though, sometimes i find it easier to take the strings out through the rear trem cavity as the ball end can get stuck in the saddle unless you loosen it all the way(dont like doing this cus im afraid that something might ping off into the same place that all dropped picks go)
newblues is offline
post #3 of 3 (permalink) Old 11-23-2015, 12:10 PM
I found that leaving the end balls on an Edge pro can sometimes result in a bit of a pain to get them out when you change strings, so i cut them off, but other than that it makes no difference really, the trem is designed to work both ways so don't worry about it.
Rafafas is offline
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
Advice needed! FailToShred All Other Guitars (including Prestige) 19 12-24-2007 04:48 AM
Some advice needed. beckisagod Ibanez JEM, UV, JS & Other Signature Models 32 08-31-2005 12:29 PM
Advice needed. What would you do? (ibanez - fixed bridge) wilch All Other Guitars (including Prestige) 33 06-30-2003 08:34 AM
