Aftermarket Chinese Tremolo Arm - Jemsite
post #1 of 5 (permalink) Old 06-14-2018, 07:28 PM Thread Starter
I ned a spare tremolo arm for my Ibanez Edge Original - and I saw an Ibanez compatible arm on eBay for £2:
Is this total rubbish? Or is it likely to work? Seems a simple enough design to implement...
Jay Menon is offline
post #2 of 5 (permalink) Old 06-14-2018, 07:28 PM Thread Starter
Re: Aftermarket Chinese Tremolo Arm
Here is a link, though there are many such vendors...
https://www.ebay.co.uk/itm/Direct-In...53.m1438.l2649
post #3 of 5 (permalink) Old 06-18-2018, 03:03 AM
I avoid Chinese repair parts whenever possible. The materials & how well it fits tend to be incredibly inferior. Also China doesn't have any false advertising laws. If you look at Chinese vendors on eBay, you'll see them hocking original Edge trems, but if you look closely you'll see they're actually Edge 3. I would avoid it. It will probably break on your first hard pull-up.
snaggleyoda is offline
post #4 of 5 (permalink) Old 06-18-2018, 06:58 AM
It's junk, as stated the steel used will be of very poor quality and will fatigue extremely quickly breaking at the thin part where the plastic bushings fit, you will then have a piece of cheap metal stuck in your expensive Edge trem preventing you from fitting another arm.
Buy a genuine part.
sepulchrave is offline
post #5 of 5 (permalink) Old 06-18-2018, 09:16 PM
Reviews: 120
Or better yet, buy a replacement Floyd Rose push in arm assembly. They're designed similar to the Gotoh units, and bypass the issues that can occur with the Edge design.
LonePhantom is offline
tremolo arm
LF: Jem aftermarket body & Tree of Life aftermarket neck supergirl20_06 Classified Ads: Guitars and Gear 3 03-04-2012 05:57 PM
LF: Jem aftermarket body & Three of Life aftermarket neck supergirl20_06 Classified Ads: Guitars and Gear 0 02-06-2012 06:13 AM
Wtb: jem back tremolo cavity plate and edge tremolo arm JemSearcher Classified Ads: Ibanez JEM/UV Guitars 0 01-26-2012 11:17 PM
edge pro tremolo arm and arm holder adjustment tonesponge All Other Guitars (including Prestige) 6 10-12-2006 05:43 PM
aedge pro tremolo arm and arm holder adjustment tonesponge Tech: Setup, Repairs and Mods 1 10-06-2006 10:16 AM
