Anyone interested in a Drop D for lo-pro Edge? - Jemsite
post #1 of 11 (permalink) Old 02-15-2006, 10:49 PM Thread Starter
Hey guys,
I have made a Drop D lever that fits on the back of a Lo-Pro Edge and I will be making a couple for myself. There is no modification needed to the guitar or the LO-pro other than needing to block the trem or use a trem stalizer(which is what i do).
Any of you guys interested in something like this? The price would be about $50.
Thanks.
John
john1880 is offline
post #2 of 11 (permalink) Old 02-15-2006, 10:50 PM Thread Starter
Re: Anyone interested in a Drop D for lo-pro Edge?
sorry. trem "STABILIZER"...
john1880 is offline
post #3 of 11 (permalink) Old 02-17-2006, 11:29 AM
yeah...definitely interested.
what's the material it's made of?
can you post a pic of it installed?
Do you think it will do a drop-A on a 7string?
Entropy is offline
post #4 of 11 (permalink) Old 02-17-2006, 08:45 PM Thread Starter
it will be made of stainless steel or tool steel. probably stainless steel. i can't post a pic yet because the design is still unprotected right now. i have a seven string. i'll check that out and let you know. thanks.
john1880 is offline
post #5 of 11 (permalink) Old 02-18-2006, 12:04 AM
I would be very interested in two or three of these. I'm guessing you are going through the patenting stage now so we can get a look at the design? Also, how do you construct it? CNC, lathe, milling, casting, forging or something else? i'm just asking because if i was going to get something like this, it'd be great if it was well made and lasted as long as the trem. Keep up the good work! Cheers
ibanez.shredder is offline
post #6 of 11 (permalink) Old 02-18-2006, 08:58 AM
Yeah i'd be interested in one for a 7-string, though my trem is a Lo TRS.
Chud is offline
post #7 of 11 (permalink) Old 02-18-2006, 07:25 PM
There already is a stabilizer available
Ant1981 is offline
post #8 of 11 (permalink) Old 02-19-2006, 04:59 PM Thread Starter
These will be milled from a solid piece of Stainless steel on a CNC, and I designed it on a Mastercam program. I have made a version for the regular Edge from the same material and it shows no where after a year, and I drop D a lot.
Chud, this will NOT work on a non lo-pro, but the D-tuna may work for you.
Yes, I am in the beginning of the patent stages, so once I can release the design, I will email pictures to those of you who are interested.
Ant1981: this is not a stabilizer. It's a drop-D attachment for the Lo-Pro.
Thanks!
John
john1880 is offline
post #9 of 11 (permalink) Old 02-19-2006, 05:19 PM
What about the edge pro tremolo?
post #10 of 11 (permalink) Old 02-19-2006, 09:35 PM
How does it work John?
Usually I would use a stabilizer and use the fine tuner wound in to tune to E then wind it out to drop to D.
Without the stabilizer, every other string goes slightly out of tune as the tension of the E string slackens as it is dropping to D.
Ant1981 is offline
post #11 of 11 (permalink) Old 02-20-2006, 10:16 PM Thread Starter
i don't have an edge pro. if i can get a look at one i will let you know.
ant1981: yes, you still need a stabilizer, but now you would just pull the lever out and it's in Drop D position. push it in and it's back up to E. Just like the EVH Dtuna works, but it's a completely different design since the EVH wont wotk on lo profile trems.
Thanks.
john1880 is offline
edge pro trem , edge pro tremolo , pro edge , pro tremolo
Suggestions for drop-drop-drop tuned 8 strings Josephmetal All Other Guitars (including Prestige) 10 10-09-2013 03:41 PM
Edge Zero II can't drop D ? aznricey All Other Guitars (including Prestige) 21 09-18-2012 08:13 AM
lo-pro edge= drop C? D.M.RG7620 All Other Guitars (including Prestige) 20 07-26-2010 08:43 PM
Anyone interested in a Drp D for lo-pro Edge? john1880 Polls 4 03-22-2006 12:38 PM
Drop D tuning on an Edge Pro atarilovesyou All Other Guitars (including Prestige) 3 11-22-2005 11:20 PM
