Balancing the single coil with the humbuckers on 7RB Jem - Jemsite
post #1 of 3 (permalink) Old 07-10-2004, 08:02 PM Thread Starter
There seems to be a slight volume difference between the single coil and neck and/or bridge humbucker. Is there a way to balance out the volume discrepancies through a pickup mod/replacement? The volume difference isn't huge...but it is noticeable.
Just wondering.
88RootBeer is offline
post #2 of 3 (permalink) Old 07-11-2004, 12:27 AM
You might want to do a search on this topic, although I don't know what you'd use as a search, maybe "middle pickup" but for me, the reduced output is preferred. It's what cleans up the amp, and produces the widest tonal variation in the in between configurations. Apparently Vai feels that way too, since the Jem single is more vintage than hot in output. I myself like a real glassy, clean single in the middle.
The fast track 1 is a good higher output yet still glassy-clean middle pickup if you need it, but it will throw the look of the Jem off. I think it would look good, but not stock. Any true singles that boast higher output would also have some degree of high frequency loss or at least an overshadowing of the high freqs by the mids, and that tends to wash out the snappy attack of the in between positions.
frankfalbo is offline
post #3 of 3 (permalink) Old 07-11-2004, 04:11 AM
ScottB's Avatar
My first pro quality guitar was a '70s hardtail Strat. I thought the sound was a little weak, compared to my friends Les Paul, so I put 3 Dimarzio SDS-1 in place of the Fender pickups. That guitar was damn loud for a strat. The SDS-1 is almost as loud as a Gibson P-90.
ScottB is offline
bridge hum , bridge humbucker , les paul
Single Coil size humbuckers, which pot needed? Jemanized Tech: Setup, Repairs and Mods 6 02-17-2012 02:59 AM
WTB: White single coil sized humbuckers buddroyce Classified Ads: Guitars and Gear 1 10-17-2008 09:49 PM
Single Coil humbuckers? Anybody? vejiita Pickups & wiring 2 04-05-2008 08:59 AM
single coil humbuckers -Rhaab Pickups & wiring 2 01-15-2007 08:04 PM
Single Coil Sized Humbuckers wallopwallop Pickups & wiring 4 08-20-2002 04:43 PM
