Basswood repair question - Jemsite
post #1 of 18 (permalink) Old 05-05-2013, 03:13 PM Thread Starter
Ok all you pros, if I have a basswood body that has a small gouge in it where the wood is actually gone (like I cant steam it out) what do I fill it with. This would be for a stained finish not painted so it has to look as original as possible. I have tried "woodfiller" on different projects and have never really been happy with the results you could easily see the repair area.
Fastmerc is offline
post #2 of 18 (permalink) Old 05-05-2013, 04:03 PM
Reviews: 11
Re: Basswood repair question
You answered your own question. If you're looking to stain finish, there's no real way to fix it so it doesn't show. The only option is to fill and veneer.
linuxpenguin is offline
post #3 of 18 (permalink) Old 05-05-2013, 06:26 PM
If the ding is small (not over .5") drill the ding out and tap in a basswood plug with like grain in the hole, then sand flush. You can almost make it disappear if you can find a plug that has similar qualities.
~JH
worldrecordholder is offline
post #4 of 18 (permalink) Old 05-05-2013, 06:27 PM
RGTFanatic's Avatar
This^^^^
unfortunately, anything you do will show unless you fix the missing chunk and add a veneer.
If you want to go inexpensive- "Michaels" has birch veneers pretty cheap. You can always order one online too. but the birch looks good....... way better than basswood.
RGTFanatic is offline
post #5 of 18 (permalink) Old 05-05-2013, 06:29 PM
RGTFanatic's Avatar
~JH
That's SO hard to do though. the plug will be endgrain while the rest of the body is not. It's near impossible to stain match the two.
post #6 of 18 (permalink) Old 05-05-2013, 08:22 PM
Reviews: 11
Ryc, I wish that didnt get swirled . I bet it would look great with a vintage violin burst style finish
post #7 of 18 (permalink) Old 05-05-2013, 08:38 PM
RGTFanatic's Avatar
Don't worry man, I have PLENTY more projects to go........
post #8 of 18 (permalink) Old 05-05-2013, 08:41 PM
RGTFanatic's Avatar
I'm doing a 7421 that will be a culmination of all the little things I did on other guitars......... it's either gonna be really cool, or a big flop
post #9 of 18 (permalink) Old 05-05-2013, 09:33 PM
Reviews: 120
I'm sure it'll be awesome mate.
LonePhantom is offline
post #10 of 18 (permalink) Old 05-05-2013, 10:49 PM Thread Starter
Sadly, this ding is right on the sharp edge of an rg style body that is already stained, so I would be trying to repair and match existing stain, it is nothing I can veneer over or make a plug for. I did get one suggestion of sanding down some basswood taking the sawdust and mixing a little woodglue with it but Im not sure that would work either.
Fastmerc is offline
post #11 of 18 (permalink) Old 05-06-2013, 12:42 AM
Reviews: 11
is that a burnt stained blue style finish? if so, do the wood filler and just "burn" that section of the horn lol
post #12 of 18 (permalink) Old 05-06-2013, 08:38 AM
I've done this with satisfactory results. try it on a spare piece of wood first to try it out. Actually I did it on a ongoing padauk build (thread soon) the sawdust is orange. I bagged a bunch of it up after jigs sawing just in case and I did end up using some as filler on one spot.
GUITARMAGEDDON is offline
post #13 of 18 (permalink) Old 05-06-2013, 04:53 PM
RGTFanatic's Avatar
This is what I would do too..........
I thought we were talking about a big chunk. This will NEVER be seen.
post #14 of 18 (permalink) Old 05-06-2013, 05:30 PM Thread Starter
I thought about that also, but I was unsure how the heat would affect any fillers, might make them shrink or crack?
Fastmerc is offline
post #15 of 18 (permalink) Old 05-06-2013, 05:34 PM
RGTFanatic's Avatar
Maybe, but you can drop-fill it before doing the clear. It will be seamless. The same thing will happen with sawdust loaded glue.
Basswood vs Mahagony Question OCDemon Ibanez JEM, UV, JS & Other Signature Models 18 10-21-2010 03:20 PM
Question About a Possible Repair *56k* JeffWiredBeck24 Tech: Setup, Repairs and Mods 4 08-09-2007 03:16 AM
Tube amp repair question.... Rotti Tech: Setup, Repairs and Mods 5 10-19-2006 08:22 PM
Paint repair question Tragical Tech: Setup, Repairs and Mods 2 09-20-2006 01:09 AM
UV body repair question... metalxmike Tech: Setup, Repairs and Mods 1 08-20-2004 09:53 PM
