Battery into a JEM - Jemsite
post #1 of 7 (permalink) Old 02-03-2015, 06:55 AM Thread Starter
Battery into a JEM
Hey guys,
I want to switch some stuff on one of my Ibanez JEM,
I'm also thinking about a sustaniac, any idears where to put the battery without taking of wood?
- Or are u guys thinking doing a hole for the battery is not big of a deal?
Thanks for your answer.
Max
GuitKaz is offline
post #2 of 7 (permalink) Old 02-03-2015, 02:06 PM
Re: Battery into a JEM
Check the jem20th.
morien is offline
post #3 of 7 (permalink) Old 02-03-2015, 02:17 PM
If you can find a way to safely out it into the output jack cavity, I'd say put it there, or fit it snugly in with some foam or something if it's backrouted
Kyle am I is offline
post #4 of 7 (permalink) Old 02-03-2015, 04:33 PM Thread Starter
Well i think there are only 4 options:
- put it in the output jack (need to remove some wood there to make it fit)
- put it inside the pickguard (well its rly ****ty if u have to remove the whole pickguard for a battery change, right?)
- put it at the springs on the back, and use only 2 springs instead of 3. (well i wont like this cause it changes the feeling of the trem)
- do a proper battery case, with removing alot of wood.(not sure if i like this)
any more idears?
GuitKaz is offline
post #5 of 7 (permalink) Old 02-03-2015, 05:41 PM Thread Starter
*misstake*
GuitKaz is offline
post #6 of 7 (permalink) Old 02-03-2015, 08:40 PM
if you regularly use a strap, just tape/cable tie/velcro the battery to that and run the wires to it.
Or get a strap with a pouch for a wireless mic, and put that battery in there.
then if you decide you dont like the sustaniac you can remove it without leaving a hole in your jem
I have one in my rg1527, installed it years ago..
also I forget the name of it but you can also get a much thinner lithium ion 9v battery that you could surface mount on the back, I was reading about them a few days ago but forgot to bookmark it.
magic_golem is offline
post #7 of 7 (permalink) Old 02-05-2015, 03:06 AM Thread Starter
Well it will stay in there anyway, cause i need it for sure on some studio stuff i have to do.
But still i kinda dont like the idear to drill holes in this nice guitar ;P
A guitar builder will do stuff for me anyway, but i want to check my options here.
I will go for a 4 pu setup anyway, so this brings some more little changes with it.
Dimarzio Evo - Dimarzio Evo - Duncan Hot Rail (SC) - Sustainiac (SC) Both the duncan and the sustainiac put in the point where the Dimarzio Evo sits right now. Since might not 100% fit, not sure. Didnt looked under the pickguard so far ;P
Greetings.
GuitKaz is offline
Does the Quadraverb have a battery? abwalsh Gear, Equipment, Recording & Off Topic 2 06-22-2006 12:29 PM
EMG's Battery ??? tchintao Tech: Setup, Repairs and Mods 2 02-10-2005 09:31 AM
NI Battery J Todd Beachler Gear, Equipment, Recording & Off Topic 5 01-20-2004 07:45 PM
Battery FinnJ Gear, Equipment, Recording & Off Topic 6 08-06-2003 06:08 PM
Battery box reguv760 Tech: Setup, Repairs and Mods 1 05-03-2001 11:02 PM
