Best cloth to wipe strings after playing? - Jemsite
post #1 of 18 (permalink) Old 09-24-2011, 01:40 AM Thread Starter
What is the best cloth to wipe strings of the guitar after playing ? Is any regular cloth around the house that is clean going to do the trick? Or do I need to get one from a music store specifically?
How often do you guys wash yours ?
abstract_noise is offline
post #2 of 18 (permalink) Old 09-24-2011, 02:37 AM
Reviews: 64
Re: Best cloth to wipe strings after playing?
Seriously.......................best cloth to wipe strings???!!!
LOL some guys are worse than chicks!
While they're buying shoes some guys are buying "special" clothes to wipe strings!
For the love of God just play that guitar
Sorry I couldn't help myself, this is way too much for me bwahahahahahahahahahhaa
6fingers is offline
post #3 of 18 (permalink) Old 09-24-2011, 07:58 AM
Old T-shirt cut into rags works, as does a microfiber cloth or flannel. Just wipe it down when you put it away, I keep one in every case and a bandanna in my back pocket at gigs.
musikron is offline
post #4 of 18 (permalink) Old 09-24-2011, 01:28 PM Thread Starter
Unhappy Re: Best cloth to wipe strings after playing?
Lol, I'm sorry......
I have OCD actually.... that's why I always worry about the most miniscule and stupid things....
Sadly, the sad thing is I honestly lose sleep thinking about what to use to wipe the strings, wondering if I used the correct material, and if I don't use a specific cloth for guitars, I feel like I did it wrong.... I really can't sleep after....
Yeah so sorry...
post #5 of 18 (permalink) Old 09-24-2011, 01:31 PM Thread Starter
Thank you sir.
post #6 of 18 (permalink) Old 09-25-2011, 08:31 PM
Any cotton cloth like old t-shirt will do. I like to soak it in isopropyl alcohol (rubbing alcohol) first and then wrap it around the string and slide it up and down the neck. Pinch the string through the rag. Doing this really gets it squeaky clean and all the ****, gunk, skin and crap is cleaned off the string. My strings last forever by doing this.
Give it a try - you'll be surprised how well this works.
dj
djem is offline
post #7 of 18 (permalink) Old 09-26-2011, 07:45 AM
i use a normal micro fibre one
dont think it really matters unless ur playing guitar with sweaty as fingers
takes like 2 secs to wipe down
SandmaN211 is offline
post #8 of 18 (permalink) Old 09-26-2011, 11:56 AM
spray some wd-40 to some old cloth, or microfiber. place something (thick paper, plastic sheet?) between the strings and the fretboard, just to protect it from wd-40. wipe the strings. works great for me.
roadrunner is offline
post #9 of 18 (permalink) Old 09-26-2011, 12:47 PM
BAD idea
musikron is offline
post #10 of 18 (permalink) Old 09-26-2011, 12:59 PM
BAD idea
...because?
post #11 of 18 (permalink) Old 09-26-2011, 01:02 PM
Whatever you use, always clean underneath the strings.
tearsx is offline
post #12 of 18 (permalink) Old 09-26-2011, 02:43 PM
WD-40 leaves a film that attracts dirt, and impregnates the wood of the fingerboard. It can cause issues as trivial as staining or as serious as lifting frets. The goal is to remove gunk from the guitar, not add a product that attracts it.
musikron is offline
post #13 of 18 (permalink) Old 09-26-2011, 02:58 PM
I agree totally, that's why I wrote "place something (thick paper, plastic sheet?) between the strings and the fretboard, just to protect it from wd-40" so the cloth only touches the strings, not the frets or the board.
post #14 of 18 (permalink) Old 09-26-2011, 03:17 PM
Correct because WD-40 is a hydrocarbon based lubricant - the propellant evaporates while the 'oil' is left behind. The whole idea is to remove any oil from strings as it will attract dirt that will pack into the string windings.
Using a sovent like isopropyl alcohol (which is dirt cheap), napthalene, etc. is preferable as it does not leave a residue.
djem is offline
post #15 of 18 (permalink) Old 09-26-2011, 03:28 PM
+1
That's what I've always done!
tearsx is offline
FS UK: GHS Gorgomyte Fret Polishing Cloth (£11) axemanrio Classified Ads: Guitars and Gear 0 08-05-2009 05:02 AM
A cloth/fabric RG! Post your ideas Reinder All Other Guitars (including Prestige) 12 08-05-2007 07:29 PM
What kind of material cloth should wipe my guitar with? jpwannabe Tech: Setup, Repairs and Mods 8 06-25-2003 07:44 AM
Floral pattern cloth - Help in a refin Fastmerc Ibanez JEM, UV, JS & Other Signature Models 9 11-04-2001 03:59 PM
