Blocking Edge Pro for string change - can't remember? - Jemsite
post #1 of 10 (permalink) Old 09-18-2011, 03:56 PM Thread Starter
Silly question, but for the life of me I can't remember if you need to block the trem on an Edge Pro (similar to Edge) for complete string change. Restrung it for the first time yesterday (had it for a year...yeah, don't play this one as much as other two with orig. Edge). The bridge sunk right into the cavity. Had to end up fiddling around with the trem screws in the back to get it back parallel but something tells me I did this wrong. Same results as it's fine now but more time consuming. Any help here?
Tannen is offline
post #2 of 10 (permalink) Old 09-18-2011, 04:13 PM
Re: Blocking Edge Pro for string change - can't remember?
You should only change one string at a time. See if you can get the same brand/thickness as the previous strings. Remember to stretch them properly. I don't usually block my trem for this. It looks like I have a talent for it. I just changed from E standard to D standard in 5 minutes while watching a tv show. If you need to block it to get it right, you should measure the space between the trem block and make some wood blocks. Or you could use a tremol-no.
TheFreak777 is offline
post #3 of 10 (permalink) Old 09-18-2011, 04:17 PM Thread Starter
I usually go through a full setup during string changes. Clean fretboard, oil if necessary etc. so this wouldn't apply to me, but for sure no block needed for a single string change just wondering about the whole thing.
Tannen is offline
post #4 of 10 (permalink) Old 09-18-2011, 04:38 PM
Tremol-no's own website states that it isn't strong enough to handle the tension of all the springs. It only works if you're changing one at a time, which is clearly not the point of this thread.
Personally, I just set up my trems every string change, since I use elixers its not a frequent hassle.
GuitarBizarre is offline
post #5 of 10 (permalink) Old 09-18-2011, 06:01 PM
RGTFanatic's Avatar
....or simply sticking a plastic soda/water bottle cap in the cavity to hold the bridge up would work nicely.
There's no need to complicate this. He's only blocking it for string changes. no need for specially cut blocks of wood or tremel-no's or any other tools.
Ryc
RGTFanatic is offline
post #6 of 10 (permalink) Old 09-18-2011, 06:11 PM Thread Starter
There's no need to complicate this. He's only blocking it for string changes. no need for specially cut on blocks of wood or tremel-no's or any other tools.
Ryc
That's what I just tried but doesn't fit the cavity but I guess it doesn't have to go in completely? On a side note, I just found a 9V wrapped in electrical tape so I'm thinking it I stick that in it should work. Even if I just goes in slightly I'm thinking as long as it does pop out and it's keeping the bridge down it should be fine...don't need to complicate things lol Bottom line is I guess some sort of block is needed.
Tannen is offline
post #7 of 10 (permalink) Old 09-18-2011, 07:02 PM
I block all my trems with an old 9v battery . fits perfect.
GUITARMAGEDDON is offline
post #8 of 10 (permalink) Old 09-18-2011, 08:00 PM
Reviews: 59
I've got a padded pistol grip C-CLamp that I'll use with the trem bar for quick changes. Otherwise, the battery is a good idea, as is the bottle caps.
smooth55 is offline
post #9 of 10 (permalink) Old 09-19-2011, 06:31 AM
I use a Mars eraser. It is the perfect size. It's also nice and soft so it won't scratch anything.
xXLinkageXx is offline
post #10 of 10 (permalink) Old 09-19-2011, 11:21 AM Thread Starter
Thanks for all the feedback guys. A block is needed for an Edge Pro after all.
Tannen is offline
Jerry Rig Edge III blocking GuitarEvan07 Tech: Setup, Repairs and Mods 4 07-16-2008 01:22 AM
Blocking an edge pro? 03hal All Other Guitars (including Prestige) 17 08-19-2006 10:09 AM
Thinking about blocking my edge pro after +2.5 themaidenmaniac Ibanez JEM, UV, JS & Other Signature Models 4 04-24-2006 05:38 AM
Blocking an Edge Pro nuno Tech: Setup, Repairs and Mods 4 10-06-2003 07:57 AM
String tension on Edge - It shouldn't change when bent? Impo YngVaiTriani Tech: Setup, Repairs and Mods 2 09-23-2001 04:57 PM
