bolt-on neck shifting problem. - Jemsite
post #1 of 2 (permalink) Old 03-31-2004, 04:27 PM Thread Starter
One of my guitars is an esp kh-2 bolt-on. The other day I slightly knocked the headstock without causing damage. After my relief I noticed the neck had shifted as the treble strings had moved closer to the edge of the fretboard as though the neck is slightly loose, I checked the screws at the back of the neck plate and they are tight is there anything I can do to fix this problem or do you think maybe a pro could fix this for me? thanks.
big h is offline
post #2 of 2 (permalink) Old 03-31-2004, 04:44 PM
site founder 0% owner
jemsite's Avatar
http://www.jemsite.com/tech/t_3other.htm#neckpocket
you can DIY if you are handy with a screwdriver
...glen
jemsite is offline
neck plate
Ibanez bolt on basswood/bolt on mahogany/neck through KevinMarchesini All Other Guitars (including Prestige) 2 05-12-2012 08:19 PM
Bolt On vs Neck-Thru adil2552 Tech: Setup, Repairs and Mods 10 07-22-2011 11:03 PM
G&L 3-Bolt neck plates? ELicari All Other Guitars (including Prestige) 1 01-23-2008 08:49 PM
Bolt-on VS neck-thru hollow125 Ibanez JEM, UV, JS & Other Signature Models 17 06-09-2007 10:49 PM
New Neck-Through vs Bolt-On The_Grindfiend Tech: Setup, Repairs and Mods 22 09-06-2004 01:36 AM
