Bought Jem 7vwh need help with edge pro height please - Jemsite
post #1 of 3 (permalink) Old 04-08-2018, 09:43 AM Thread Starter
Hey guys is this too low for the edge pro to be in the cavity? The action is already too high and when I compare to my rg1570 the 1570 edge pro is much higher out the cavity and the action is alot lower.. Where do I go from here
qwilder11 is offline
post #2 of 3 (permalink) Old 04-08-2018, 10:07 AM
Re: Bought Jem 7vwh need help with edge pro height please
Edge pro trem sits deeper in the cavity and the baseplate has to be paralel to the guitar body, not angled as the edge/lo-pro units. Anyways, if the trem is too low and the action remains high, makes me think your neck pocket needs a shim to raise the neck pocket and lower the action. Is easy to do, visit Ibanez Rules tech section to see in detail how to proper set up your guitar.
vyansal is offline
post #3 of 3 (permalink) Old 04-09-2018, 08:52 PM
sounds like it needs a full setup.... I'd start with checking if the neck is shimmed and how much
this can lead to the bridge needing to be high with regard to the recess because of the neck angle
neck relief will also play its part
like i said a full setup
enjoy
LACS-plus is offline
A Jem 7VWH 2002, with ebony fretboard and... Edge Pro? Is it legit? Rachmaninoff Ibanez JEM, UV, JS & Other Signature Models 8 08-26-2014 07:45 AM
Jem 7VWH W/Edge Pro Good or Bad? TremoJem Ibanez JEM, UV, JS & Other Signature Models 4 09-20-2012 11:58 AM
2010 Jem 7vwh now with lo pro edge MacMusica Ibanez JEM, UV, JS & Other Signature Models 11 07-11-2010 10:06 PM
Ibanez EDGE PRO tremolo, GOLD for Jem 7VWH and others, near new atlantajem Classified Ads: Guitars and Gear 1 02-08-2010 04:15 PM
Wanted : Jem 7vwh with edge pro? richo00175 Classified Ads: Ibanez JEM/UV Guitars 0 05-04-2007 07:53 PM
