Bridge Stud issue - Jemsite
post #1 of 4 (permalink) Old 01-02-2012, 04:15 PM Thread Starter
Bridge Stud issue
I'm installing a powerbridge in a guitar with the tune o matic style bridge. The existing studs in the guitar are the tonepros style. The studs are much too wide for the new bridge. They did include studs but they swim in the holes. I have a call into fishman but they are closed. In the meantime I figure I have 2 options.
Use some sort of adapter to go from the large thread the tonepro left behind to the smaller one and use the included studs
Drill the new (expensive!) bridge to fit the tonepro stud.
Any thoughts?
Shredso is offline
post #2 of 4 (permalink) Old 01-02-2012, 04:41 PM
Re: Bridge Stud issue
Or the right way maybe? Half assed repairs and mods give half assed results. The bridge is a very crucial component in sustain, tone, and intonation, why do it wrong? All you will do is frustrate yourself and be full of regret.
Dowel and drill the proper holes for the new studs. Takes about 5 minutes of work, with a few hours in between for glue to dry. If you don't have a drillpress (you should) then just take it to a luthier, thats a cheap and easy job.
musikron is offline
post #3 of 4 (permalink) Old 01-02-2012, 11:56 PM Thread Starter
I appreciate your response and I am not looking to hack this job. This is for a paid customer, I typically don't deal with repairs beyond setups, basic fretwork and mainly electronics. I was mostly hoping someone made a stud that would fit in the existing thread (I have a crude gauge, I would confirm these numbers before buying anything). The male thread appears to be 5/16". The part that goes into the bridge is 1/4" (no thread). The new bridge needs a hole the size of a #8 screw (no thread). I was mostly hoping someone made a new stud that started at that 5/16" thread and ended at #8 rather than 1/4" post.
Not really knowing what material or how well the new bridge is made I think your solution will probably be the right one. I pulled the anchors out of my Les Paul very easily, these seem like they might be glued. is there any trick to getting these out?
Assuming I can get the old anchors out, does it make a big difference what the dowel is made of? In the little research I did some people said pine would be fine, lots of people suggested oak, and I also saw a lot of posts saying if you need to drill into it a plug is the only way to go. Keep in mind this is an inexpensive basswood guitar. Thanks.
Ed.
Shredso is offline
post #4 of 4 (permalink) Old 01-03-2012, 05:51 AM
Get your studs custom made?
Leave's the body original and the proces reversable.( in case of non satisfied customer).
If you got al the measurments right a handy metal craftsmen can help you out.
Death.by.G-string is offline
fishman , tonepros
Lo Pro Bridge Stud Lock Screws? ed3120 Tech: Setup, Repairs and Mods 3 01-13-2007 11:55 AM
Gibralter bridge issue, (RGA121). mityjoeyoungxnj Tech: Setup, Repairs and Mods 3 12-18-2006 09:01 PM
FS: Edge Bridge & Stud Assy damo7v Classified Ads: Guitars and Gear 3 10-27-2006 11:49 AM
Bridge grounding issue on RGA121 Vinco Pickups & wiring 6 09-29-2005 09:00 AM
Confusion over recent JEMs and bridge stud set screws :( heeby1 Ibanez JEM, UV, JS & Other Signature Models 3 03-19-2005 10:08 PM
