Broken neck repair on a '90 550PN - Jemsite
post #1 of 6 (permalink) Old 02-08-2013, 05:26 AM Thread Starter
Hello Everybody!
I've just purchased (not yet received) a '90 RG550PN with a broken neck. I've researched on how to potentially fix the problem (found it on Ibanez Rules!! - actually looks like a similar break, but worse!). Question is for any member who has done this kind of repair.
I'm planning on stripping the neck and doing a tung oil and wax finish (already done this on my other 550 with great results). Would I be better off repairing the break, then refinishing the neck? or the other way around. I'm not sure what would get the best results,
Also, from the limited pictures I have, it looks like a dirty break (Been there a while) - is there anyway I can clean the break before repairing so it's not so obvious?
Thanks for any advice,
J
Ralf MacAardvark is offline
post #2 of 6 (permalink) Old 02-08-2013, 05:31 AM
Reviews: 120
Re: Broken neck repair on a '90 550PN
Without photos it's hard to tell, but I'd definitely fix then refinish. Clean it up as best you can and glue it.
LonePhantom is offline
post #3 of 6 (permalink) Old 02-08-2013, 05:38 AM Thread Starter
Thanks LonePhantom,
New member, so can't post pics yet (and I don't have it yet which makes it even harder to take more pics anyway).
J
post #4 of 6 (permalink) Old 02-08-2013, 06:14 AM
Reviews: 37
Originally Posted by Ralf MacAardvark View Post
Thanks LonePhantom,
J
when you get the neck go to photobucket.com upload photo then copy the link on photo that says direct image code and paste it here and BOOM done.
andrewsfury is offline
post #5 of 6 (permalink) Old 02-08-2013, 06:55 AM
i have done a couple of neck repairs. Even if it looks bad as long as it didn't shatter and fragment you should be good.
The more jagged the better actually because it means more surface area for the glue to bind with the wood.
wood glue, clamps and heavy duty zip ties will usually do it.
j.arledge is offline
post #6 of 6 (permalink) Old 02-15-2013, 04:15 AM Thread Starter
Thanks all for the advice,
I've still not received the 550, but I've decided which approach to take.
I'll repair the break then refinish. From the info I've got from research, it looks (relatively) easy to repair. The quality of the repair is another thing! So, I've still got to get some decent clamps and glue to be able to do the job properly, then I'll give it a crack!
I'll try and post pics as I go!
J
broken , neck , repair , rg550
Broken wood piece between H & S slots- repair? gauchosilvertone Tech: Setup, Repairs and Mods 2 01-18-2012 06:06 PM
Broken Neck help SkyNorton Tech: Setup, Repairs and Mods 9 12-22-2010 10:56 PM
Here is my broken/repair jem...jaja ponxho Ibanez JEM, UV, JS & Other Signature Models 4 12-04-2003 11:07 AM
broken neck!:( haplo21 All Other Guitars (including Prestige) 7 05-04-2003 04:41 AM
