Broken wood piece between H & S slots- repair? - Jemsite
post #1 of 3 (permalink) Old 01-18-2012, 05:55 PM Thread Starter
I'm basically overhauling my 1990 RG550 Coral Mist Metallic, including new pickups and, while I'm at it, a decent cleaning (plus hopefully getting rid of an awful stale smoke smell).
I removed the pickguard and as I was swabbing out the pickup cavities, a piece of the "wall" between the neck humbucker slot and the single coil slot broke off, very cleanly. I would say it had even been broken before, but there's no residue from old glue or anything like that.
I'm figuring this is a very simple wood glue repair, and I'm not overly worried about cosmetics since it's under the pickguard, but just wanted to ask if there are any pitfalls to avoid. I don't have any actual clamps either as I'm a novice repairman- suggestions as to how to hold the piece in place as the glue dries for however long.
Thoughts appreciated on a topic I've not seen before-
-Gaucho
gauchosilvertone is offline
post #2 of 3 (permalink) Old 01-18-2012, 05:58 PM
RGTFanatic's Avatar
Re: Broken wood piece between H & S slots- repair?
this would be easier with pics.........
My first thought is that nothing needs to be done........this should not affect playability at all.
RGTFanatic is offline
post #3 of 3 (permalink) Old 01-18-2012, 06:06 PM
Glue it back on, then use a weight to hold it while the glue dries. Very easy, especially if you don't have to touch up the finish. Just keep everything clean,
musikron is offline
body repair , rg550 , woodwork
"every piece of wood has a pitch" Black Napkins Tech: Setup, Repairs and Mods 49 06-28-2006 03:41 AM
sliding miter saw or Radial saw for cutting fret slots?? SilverSurfer2 Tech: Setup, Repairs and Mods 6 05-22-2004 07:54 PM
Here is my broken/repair jem...jaja ponxho Ibanez JEM, UV, JS & Other Signature Models 4 12-04-2003 11:07 AM
are all Jems out of 1 piece wood ? rickyrocket Ibanez JEM, UV, JS & Other Signature Models 1 09-04-2002 04:33 PM
Broken wood on body...Fixable? - under the tremolo craig Tech: Setup, Repairs and Mods 1 02-06-2002 03:44 PM
