Busted Sperzel Tuner, Salvageable? - Jemsite
post #1 of 3 (permalink) Old 11-07-2015, 10:53 AM Thread Starter
webmaestro's Avatar
The little tab/alignment thingy busted clean off (see photo) one of my Sperzel locking tuners during installation last night. Any chance I can still use this tuner, or is it toast?
In a nutshell, the little guide holes I drilled were pretty damn tight, so pressing the tuners into place was quite a challenge, but I got all but one in. That particular one just would NOT go in, so after getting it about halfway in, I started working it back out (so that I could widen the hole a bit).
That's when the little thingy pulled right out of the tuner housing. I had to pull the tab out of the headstock with vice grips.
webmaestro is offline
post #2 of 3 (permalink) Old 11-08-2015, 04:13 PM
Re: Busted Sperzel Tuner, Salvageable?
If you can extract the busted stump of roll pin out of the housing, you could replace that with another roll pin of the same spec as original, widen your headstock hole to the right size, and go again.
A small screw extractor /might/ get a bite and get that stump moving; I think I'd actually try to get a small tap to start engaging the stump, and once it has a bite, use that as a puller to try pulling the stump straight up and out.
If you can't extract, perhaps there's a way to use a thinner solid pin tapped down into the center of the original roll pin after reinserting the large bit into the hole - the thinner solid (stainless?) pin might reinforce the original pin enough to keep it from shifting/turning in its mounting hole.
Just a couple of thoughts off the top of my head.
steve is offline
post #3 of 3 (permalink) Old 11-08-2015, 04:32 PM Thread Starter
webmaestro's Avatar
I managed to remedy the situation.
I tapped the little roll pin back into the hole I'd pre-drilled, and it left just enough sticking up above the wood for the tuner housing to grab onto. That alone was enough to keep the tuner from moving once everything was assembled and tightened.
Works like a champ!
(Pics) Help. Are These 2027X Knife Edges Salvageable? webmaestro Tech: Setup, Repairs and Mods 15 05-11-2014 08:16 PM
PM system busted? LonePhantom Forum Announcements and Member Help 0 06-20-2011 01:21 AM
busted EDA900 tterrahs Tech: Setup, Repairs and Mods 0 11-07-2010 11:51 PM
Sperzel Locking Tuner Problem stratoskier Tech: Setup, Repairs and Mods 8 05-04-2005 11:34 PM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear, Equipment, Recording & Off Topic 5 02-13-2002 09:55 PM
