buzz on the low E ONLY on my RG3120, help! - Jemsite
post #1 of 2 (permalink) Old 03-17-2015, 01:23 AM Thread Starter
hey guys!
recently scored a BEAUTIFUL RG3120! I'm in love. Plays great and sounds amazing, except for the buzzing i'm getting on my low E. I typically set my guitars up with 9-42, low action, and a nearly straight neck. I have a light touch with both hands, and i like a little bit of "zing" when i hit the strings hard. But on the low E (and just the low E), i'm getting more of a "squelch" kind of sound, if that makes sense! Too much buzz that can clearly be heard through the amp.
The frets have practically zero wear on them, and its a new set of strings. i've tried adding more relief to the neck, and it doesn't really help much; maybe a little, but at the expense of making it uncomfy to play. Its not nut height, as the open E doesn't buzz.
I am looking at the neck where it joins the body, and it appears that it might have a decently big shim at the very back of the pocket (haven't taken the neck off to check yet). The 24th fret is definitely more high off of the face of the body than the 17th is. I'm thinking it may be at too sharp of an angle, causing the low E string (which is of course fatter than the other strings) to strike some high frets when it is fully vibrating.
Does that make sense to you guys? Should removing the shim or adding a similarly sized shim to the front of the pocket help?
Thanks chums!
HumanFuseBen is offline
post #2 of 2 (permalink) Old 03-17-2015, 01:44 AM
Re: buzz on the low E ONLY on my RG3120, help!
the neck shim could be the issue. Is there any one place on the neck the buzz sounds worse or sounds like the same note? On rare occasion a high fret in the upper(13-24) will buzz when fretting a lower note 1-12 on the same string.
If you have a hard small straight edge try rocking the frets to make sure one isn't a little high.
j.arledge is offline
rg3120
FT: Black Ibanez RG3120 for Vintage Violin RG3120 SnakeEyes Classified Ads: Guitars and Gear 1 07-25-2012 06:36 PM
fret BUZZ BUZZ BUZZ lotusroadster Tech: Setup, Repairs and Mods 10 09-23-2010 04:18 PM
Buzz Feiten my RG3120 smokingvince Tech: Setup, Repairs and Mods 2 05-27-2003 06:20 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
