Buzz in tuner - Jemsite
post #1 of 9 (permalink) Old 03-05-2013, 11:13 AM Thread Starter
Buzz in tuner
Hello,
Has anyone else run into a problem like this one? I'm getting a buzz from the 6th tuner, but only when I play the "G" string on the seventh fret, usually with an upstroke, but not completely confined to the up motion. It's loud when the guitar is not plugged in, but it's not picking up through my amp. Any feedback is helpful.
Thanks,
Bert
Guitarded is offline
post #2 of 9 (permalink) Old 03-05-2013, 11:29 AM
Re: Buzz in tuner
Did you leave the ball ends on the string at the tuner?
Rich is offline
post #3 of 9 (permalink) Old 03-05-2013, 11:37 AM Thread Starter
Re: Buzz in tuner
Hi Rich,
Yes, the balls are seated in the holders, it's been through several string changes and it's still going on.
post #4 of 9 (permalink) Old 03-05-2013, 12:11 PM
Re: Buzz in tuner
make sure your tuners are tight, not tight enough so you can't turn the tuner but enough so that they dont rattle
j.arledge is offline
post #5 of 9 (permalink) Old 03-05-2013, 12:14 PM Thread Starter
Re: Buzz in tuner
Ok, I'll check on them tonight and see where I'm at. Thanks!
post #6 of 9 (permalink) Old 03-05-2013, 01:47 PM
Re: Buzz in tuner
If you mean at the tuners the balls will vibrate at a sypathetic pitch. If you mean in the saddle then the balls are not your problem.
Rich is offline
post #7 of 9 (permalink) Old 03-05-2013, 02:02 PM Thread Starter
Re: Buzz in tuner
Hi Rich,
They are in the saddle, so it's not those suckers.
Thanks,
Bert
post #8 of 9 (permalink) Old 03-05-2013, 02:30 PM
Re: Buzz in tuner
Balls in the saddle? What bridge?
wilch is offline
post #9 of 9 (permalink) Old 03-05-2013, 02:36 PM Thread Starter
Re: Buzz in tuner
In the body of the guitar, as per the instructions. There's a little seat in the floating tremolo that mine fit into. They gave the option of cutting off the balls or letting them slide into the seats, so I usually leave them on.
fret BUZZ BUZZ BUZZ lotusroadster Tech: Setup, Repairs and Mods 10 09-23-2010 04:18 PM
FS: N-Tune Onboard Tuner - Replaces Existing Volume with Volume/Tuner! (new in box) For_The_Love_Of_Jems Classified Ads: Guitars and Gear 5 08-16-2010 07:03 PM
D-tuner tony777 Gear, Equipment, Recording & Off Topic 5 01-07-2004 03:37 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
Rack tuner - can I put a tuner in the effects loop? - I coul djrjems Gear, Equipment, Recording & Off Topic 5 02-13-2002 09:55 PM
