Buzzing Tube Screamer... - How do u overcome this? - Jemsite
post #1 of 13 (permalink) Old 01-10-2001, 09:14 PM Thread Starter
HI.
everytime i turn on my re-issue TS-9, there's this humming/ buzzing, same goes for my other tube screamer, the tone-lok TS7. what's with these pedals anyway? i don't think it's my guitar coz it's present when i tried it with all my other guitars... hope u can help me out...
germX is offline
post #2 of 13 (permalink) Old 01-11-2001, 04:13 AM
Bad cables? Bad power supply? Bad amp? Bad outlet? Bad battery?
Doink is offline
post #3 of 13 (permalink) Old 01-11-2001, 06:56 AM
What type of power source are you using?
AC adapter, or batteries?
Wil..
wilch is offline
post #4 of 13 (permalink) Old 01-11-2001, 11:20 AM
rgr
If you are using a noisy power supply that might be the problem, try it with batteries instead to see. *Like Doink and Wilch said, we need more information.
Roger
(Edited by rgr at 9:20 am on Jan. 11, 2001)
rgr is offline
post #5 of 13 (permalink) Old 01-11-2001, 11:52 AM
60 cycle hum. The scourge of all audio endeavors. I have been battling it for years. Sometimes I think I’m loosing “ground”. :biggrin:
My point… Proper grounding is the issue. If you are using the correct power supply, check and double-check any and all grounds. I personally have big problems with power supplies on stomp boxes. They are very picky and almost never have a grounding prong on the ac side. I don't know why...
bob oakman is offline
post #6 of 13 (permalink) Old 01-11-2001, 01:11 PM
Wall warts are transformers that take your 110v AC household current and knock it down to 9v DC current. To do this it uses coils of wire with lots and lots of windings (This is also why they get so warm). These windings create a stronger magnetic field around the wart than the surronding wireing(sp). This field acts like an antenea picking up 60 cycle hum from sources as far away as 100 ft.
My suggestion has always been, use batteries. In fact, in my pedal days, I used rechargable 9v batteries. They cost a bit more, but you can recharge them about 20 to 30 times before you need to replace them.
J>
Vaibanez is offline
post #7 of 13 (permalink) Old 01-12-2001, 12:56 AM
If you don't want to go the battery route, and have a bit of spare money lying around, get yourself a good (read: expensive) Boss dual rectified AC adapter.
One easy, visual way of seeing which AC adapter will be most silent is size within the same current rating.
ie. 9V 500mA noisy adapter will be smaller than a 9V 500mA quiet adapter.
Being in Australia, which uses 240V mains, I had to search for an AC adapter that would work with my Bad Horsie pedal (morley don't make 240V AC adapters for Oz). I went through 15 different adapters before settling on a Boss. Luckily the guy at the store let me try virtually every adapter they had there. Every other adapter (even a sony) produced more than your standard 60 cycle hum....the thing buzzed and BUZZED LOUD, overpowering the guitar.
Wil..
wilch is offline
post #8 of 13 (permalink) Old 01-12-2001, 08:15 PM Thread Starter
HI again. thanks for the replies.
i've been using batteries for my tube screamers. fresh batteries- hum is still there...
can it be that the source of this hum is by another FX pedal, it's just that the tube screamer acts as a trigger? i'm using the tube screamer to boost my Zoom510...
germX is offline
post #9 of 13 (permalink) Old 01-12-2001, 08:34 PM
Are you using an AC adapter for your Zoom?
That will also get you that annoying hum.
J>
Vaibanez is offline
post #10 of 13 (permalink) Old 01-15-2001, 09:15 AM
The Zoom most probably has an inherent "hum" that's inaudible when's it's just used by itself at normal volumes.
When you kick the tubescreamer in and everythings boosted the hum would also be boosted.
But it could just be that you've got a bad patch lead inbetween or something.
Wil..
wilch is offline
post #11 of 13 (permalink) Old 01-15-2001, 12:23 PM
rgr
It's probably the Zoom, especially if you are using an adapter with it. *Try bypassing the Zoom and running the TS straight into your amp. *Care to fill us in on the rest of you signal chain? *It would probably help with the diagnosis. *
Roger
rgr is offline
post #12 of 13 (permalink) Old 01-15-2001, 03:17 PM
I assume you've tried plugging in JUST the Tubescreamer and still gotten hum? Is the TS placed after the Zoom in the signal chain? If so, then it's boosting the Zoom's hum. If it's before the Zoom, then I don't know.
Doink is offline
post #13 of 13 (permalink) Old 02-14-2001, 03:37 PM
You might want to check the electronics in your guitar also and make sure that they are grounded properly.
megawzrd is offline
stomp box
Maxon Pue5 Tube Rare tube screamer! Jay21 Classified Ads: Guitars and Gear 4 06-17-2010 10:53 PM
Tube screamer ts-9 from '85 denthevetteman78 Gear, Equipment, Recording & Off Topic 3 02-12-2010 03:01 PM
WTB TS9 Tube screamer pwnzor Classified Ads: Guitars and Gear 1 12-02-2009 01:10 PM
WTB Tube Screamer or alike elchato Classified Ads: Guitars and Gear 0 12-09-2005 09:23 PM
Tube Screamer osageindy1 Gear, Equipment, Recording & Off Topic 11 10-12-2003 01:23 AM
