Can a 3 way selector fit into a 5 way casing? - Jemsite
post #1 of 5 (permalink) Old 02-07-2012, 05:53 PM Thread Starter
I'm going to be getting a 3 way lever selector for my RG471AH and was wondering if it will fit into the casing of the 5 way casing that comes with the guitar originally
andrewbear337 is offline
post #2 of 5 (permalink) Old 02-07-2012, 06:28 PM
Re: Can a 3 way selector fit into a 5 way casing?
It depends on the switch in question, but there's no reason it shouldn't if you buy one roughly the same sort of design as the old one. A 5 way switch is just a 3 way with 2 extra detents. The first "5 way" switches on old stratocasters were 3 ways with matchsticks jammed in to stick them between two positions.
Things get more complicated if you've ordered a superswitch. Those are entirely different inside and are usually slightly larger as a result of the extra configuration possibilities. In most cases though, that still isn't an issue.
GuitarBizarre is offline
post #3 of 5 (permalink) Old 02-07-2012, 09:59 PM
RGTFanatic's Avatar
OP, I'm confused....are you wanting to pull apart the original switch (3-way) and put the guts of a 5-way into it????
If so, no it wont work........the switches have nothing in common. The 5-way will screw into the body the same way as the 3-way though..........just do that.
RGTFanatic is offline
post #4 of 5 (permalink) Old 02-08-2012, 12:52 AM Thread Starter
They look like the same lever selector switch.Same everything just again the added 2 dents, but I was just hoping that I will be able to screw it into my guitar. I was thinking that the 3 way would be smaller than the 5 way casing so I wouldnt be able to screw it in
I want to take out my 5 way switch and put a 3 way in its place.
post #5 of 5 (permalink) Old 02-08-2012, 02:26 PM
no problem, they just use 2 screws.
depending on the type of switches the holes might be in different places but as you are screwing into wood thats no problem.
LostInRockFormations is offline
pickup selector
5 way selector problem Potatohead_33 Pickups & wiring 9 12-07-2009 05:17 AM
RG20th Casing Problem? PinkSpId3r All Other Guitars (including Prestige) 20 09-11-2007 02:36 AM
Awesome computer casing mi2tom Off-topic / Miscellaneous 17 10-17-2006 04:22 AM
Pots and selector chef21 Tech: Setup, Repairs and Mods 0 08-20-2005 03:22 PM
5 way selector switches The Madness Here Tech: Setup, Repairs and Mods 7 02-09-2004 05:17 PM
