Can Edge Arm Holder Fit onto Lo-TRSII - Jemsite
post #1 of 5 (permalink) Old 05-06-2004, 10:16 AM Thread Starter
Can Edge Arm Holder Fit onto Lo-TRSII or ILT Trem?
lewis_ho is offline
post #2 of 5 (permalink) Old 05-06-2004, 12:20 PM
no, cause the Edge' Arm Insert inserts into a threatened hole on the baseplate, while the TRS baseplate has not threatened hole, and it's too thin to be threatened.
nuno is offline
post #3 of 5 (permalink) Old 05-06-2004, 12:36 PM
Y do you want to change it?
c0un7d0wn is offline
post #4 of 5 (permalink) Old 05-06-2004, 03:12 PM
Although it's threaded, you can use the nut that locks it in from underneath to tighten it into the hole. It should work fine. You could even get a bigger locking washer with the nylon insert if you wanted to be sure it wouldn't come loose.
frankfalbo is offline
post #5 of 5 (permalink) Old 05-06-2004, 10:22 PM Thread Starter
Thanks. I want to change the arm because I can't afford a mod on my guitar and just want to get rid of the slop of the trem arm. The trem itself stays in tune just fine.
lewis_ho is offline
arm holder , trem arm
Edge arm holder wobble TheFreak777 Tech: Setup, Repairs and Mods 8 08-24-2011 09:34 AM
Arm holder from Edge fits ZR? Sledgeman Tech: Setup, Repairs and Mods 4 06-07-2009 03:11 PM
Edge Pro arm holder trouble ChopDuel Tech: Setup, Repairs and Mods 3 03-25-2007 06:18 AM
Tightening Edge Pro Arm Holder?? HOW?? AmazinAzian12 Tech: Setup, Repairs and Mods 10 01-11-2007 09:14 PM
How much biigger is the routing for an edge trem vs a TRSII? Rotti Tech: Setup, Repairs and Mods 20 10-28-2002 10:22 AM
