Can I add a Lo Pro Edge to this guitar? - Jemsite
post #1 of 5 (permalink) Old 12-19-2005, 03:34 PM Thread Starter
I was wondering if I could install a Lo Pro Edge to this guitar here - http://www.hamerguitars.com/?fa=detail&mid=897&sid=190#
Would any routing be required?
Also, in order to do routing, should I contact a luthier to do it?
Thanks
waylay00 is offline
post #2 of 5 (permalink) Old 12-19-2005, 04:37 PM
Gurj's Avatar
Re: Can I add a Lo Pro Edge to this guitar?
Most likely yes. I had a lo-pro fitted to my Jackson Soloist, which originally had a Schaller Floyd on it. Luckily the trem post holes didn't need to be redrilled, but I had to get a fellow jemsiter to do a bit of routing work.
Gurj is offline
post #3 of 5 (permalink) Old 12-19-2005, 04:59 PM Thread Starter
So do you think a luthier would be able to do the routing if needed?
waylay00 is offline
post #4 of 5 (permalink) Old 12-19-2005, 05:13 PM
Gurj's Avatar
Shouldn't be a problem for a luthier. But check how the trem fits first, last thing you want is for top of the body to be routed!! Then you'll need a refinish aswell, making it a very expensive project. Then again, you could always buy an Ibanez already equiped with a lo-pro
Gurj is offline
post #5 of 5 (permalink) Old 07-11-2006, 01:17 AM
Actually, a carbide router bit will do a very clean route and you can simply paint the cavity with black sheilding paint and it looks factory(I have done this on a few guitars with excellent results). As long as the stud spacing is the same 74mm, it should be a simple mod.
albee1952 is offline
jackson soloist , pro edge
Would you pay more for a guitar with an Original Edge jono Polls 31 12-09-2009 02:07 PM
Getting a guitar from Rich. Edge Zero versus Edge Pro. Which one to get? einarabelc5 All Other Guitars (including Prestige) 33 08-21-2009 05:48 AM
Edge or Lo pro into a non Ibanez guitar? Triggerman9 All Other Guitars (including Prestige) 4 02-08-2008 03:29 PM
Edge studs on an Edge Pro equipped guitar? bringer of torture Tech: Setup, Repairs and Mods 2 09-18-2007 06:28 PM
Retrofitting Edge-Pro or Lo Pro to a guitar with an OFR? waylay00 All Other Guitars (including Prestige) 7 01-06-2006 08:41 AM
