can the neck on this Gio be repaired? It has a couple of dead spots - Jemsite
 2Likes
  • 1 Post By FireEagle
  • 1 Post By jmcneill
post #1 of 10 (permalink) Old 03-18-2019, 09:50 PM Thread Starter
I got this gio as i was looking for hardware for a guitar build. This was perfect as the guy said the neck was warped beyond repair and he didn't want it anymore. Turns out i love the neck - the profile and reverse headstock have me in love. however there is a couple of deadspots and fret buzz on the guitar. Can this be fixed with some setup changes or is it toast? I don't have much experience with this sort of thing and hoping someone wiser can weigh in for me.
youtu [dot] be/iDFmcU495CM
jmcneill is offline
post #2 of 10 (permalink) Old 03-20-2019, 11:35 AM
Re: can the neck on this Gio be repaired? It has a couple of dead spots
Take it to a local guitar tech... You may just have a couple of high frets and it may be an easy fix. Good luck!!
jmcneill likes this.
FireEagle is offline
post #3 of 10 (permalink) Old 03-20-2019, 09:30 PM
it seems like it might be fixable. you may have a few high frets, but it seems more likely you need a good truss rod adjustment. Most guitar necks bow were the headstock pulls up and back toward the top of the body, it would seem your neck has the opposite bow where the neck back bows and the headstock dips and pulls toward the back side of the guitar.
as long as the neck isn't twisted in a circular fashion it should be fixable. I have only ever had one guitar out of a hundred or more that had a twisted neck. I have it now and have removed the fretboard. I plan on sanding the neck down level again from the fretboard side, making the trussrod channel deep enough the fit a new trussrod and then glue on a new fretboard, and then a full fret job.
j.arledge is offline
post #4 of 10 (permalink) Old 03-21-2019, 07:39 AM
i say it can be fixed.
musterion1973 is offline
post #5 of 10 (permalink) Old 03-22-2019, 10:40 PM
elcid's Avatar
I'm sure it's fixable, whether or not it's worth it is a different discussion.
elcid is offline
post #6 of 10 (permalink) Old 03-28-2019, 06:07 PM
Reviews: 13
Exactly, looks like the truss rod is too tight. As long as the neck isn't twisted, a small truss rod loosening and a proper fret dress would fix it.
Rachmaninoff is offline
post #7 of 10 (permalink) Old 04-02-2019, 09:39 AM Thread Starter
Thanks for all the input guys - truss rod was fine, turns out there were 2 frets that had popped and causing the issue! shouldn't be too much work to fix them. really appreciate the help, thanks!
FireEagle likes this.
jmcneill is offline
post #8 of 10 (permalink) Old 04-02-2019, 12:05 PM
Awesome... I like that neck profile too. A little more meat than the Wizard, Super Wizard, etc...
post #9 of 10 (permalink) Old 05-24-2019, 02:00 PM
it seems like it might be fixable. you may have a few high frets, but it seems more likely you need a good truss rod adjustment. Most guitar necks bow were the headstock pulls up and back toward the top of the body, it would seem your neck has the opposite bow where the neck back bows and the headstock dips and pulls toward the back side of the guitar. Tutuapp 9apps Showbox
why when the neck is not twisted in a circular way it should be repairable? What is the exact difference?
klimbo is offline
post #10 of 10 (permalink) Old 05-24-2019, 02:46 PM
a twist in a circular fashion can't be fixed by a trussrod adjustment and the neck is done for(it would need considerable amount of work to fix, much more than the guitar is worth and much more than a new neck). if it is bad enough, you'll never get the action right on the neck, nut or bridge. no amount of fret dressing/shaving can fix it 100%
if the twist is minor enough sometimes you can work with it a little bit but your action is still going to be off.
if the neck is bent forward or back with respect to the body, (no twist) a trussrod adjustment can fix that. Tussrod adjustments are easy to do too. The only time a truss rod adjustment doesn't fix this type of bending is when the truss rod is broken. I have worked on literally 100s of guitars and only ever broken one truss rod, and had one guitar that has a seriously twisted neck.
fret buzz , ibanez , neck , setup , warped
2 Ibanez Neck breaks repaired by me! Jem7RB MK Tech: Setup, Repairs and Mods 2 07-30-2012 01:37 PM
Dead Spots and String Gauge Quantum919 Tech: Setup, Repairs and Mods 4 09-23-2010 06:26 PM
dead spots miamifish Tech: Setup, Repairs and Mods 2 12-08-2009 10:10 AM
HELP PLEASE! JEM 7V REPAIRED NECK, off bay deal! supernightwish Ibanez JEM, UV, JS & Other Signature Models 4 06-09-2009 09:30 PM
dead spots dudius Tech: Setup, Repairs and Mods 4 08-31-2006 09:05 PM
