Can somebody measure their edge trem for me? - Jemsite
post #1 of 6 (permalink) Old 02-06-2015, 01:46 AM Thread Starter
Hello
I am hoping somebody here can measure their original edge trem for me.
I need to know the distance between the two posts center to center.
I also need to know the total width of the trem from outside to outside.
I cant seem to find any measurements on these or the lopro trems.
Any help you can give me would be great.
Thanks
wireman24 is offline
post #2 of 6 (permalink) Old 02-06-2015, 11:01 AM
RGTFanatic's Avatar
Re: Can somebody measure their edge trem for me?
Sure...... trem post spacing is 75mm (74.66mm actual), outside to outside is 91.5mm
RGTFanatic is offline
post #3 of 6 (permalink) Old 02-06-2015, 11:56 AM Thread Starter
Thank you so much thats a big help
post #4 of 6 (permalink) Old 02-06-2015, 12:26 PM
RGTFanatic's Avatar
NP.... happy to help.
Do you need body route dimensions as well?
post #5 of 6 (permalink) Old 02-06-2015, 02:54 PM Thread Starter
sure that would be great!
I am going to replace a trs style bridge with an original edge.
So far it looks like I will need to remove the posts plug the holes and re drill for new posts.
I think the trem cavity will be fine but your measurements will help.
I just want to make sure before I buy the new bridge.
Thanks
post #6 of 6 (permalink) Old 02-06-2015, 03:14 PM
RGTFanatic's Avatar
Thanks
I did this swap not too long ago. I put a Lo-Pro into a Lo-TRSII RG450. The only thing you have to do with the cavity is sand the sides of the route to fit the wider tail of the Lo-Pro. An Edge will require routing the far back to make room for the string lock screws. I would suggest doing a Lo-Pro instead. Same great trem with less body work required.
The TRS anchors are in the right location. They just need to be drilled wider. The correct width to fit the ED/LP anchors is 27/64th's.
http://www.jemsite.com/forums/f21/lo...te-124868.html
edge and lo pro edge
FS: Double Edge Trem (piezo equipped trem) Guitarmattms Classified Ads: Guitars and Gear 0 01-23-2014 10:12 PM
xiphos with edge pro trem and original edge studs/anchors ibanguitar All Other Guitars (including Prestige) 2 10-15-2013 10:45 PM
How to remove ZR trem, destroy it, then install Edge trem? bdk Tech: Setup, Repairs and Mods 16 07-25-2010 01:33 PM
Can someone measure their nut for me? TimS Ibanez JEM, UV, JS & Other Signature Models 13 10-29-2006 01:25 PM
FT: Black Cosmo Lo-Pro Edge Trem for your Chrome Lo-Pro or Original Edge Trem parker_fly Classified Ads: Guitars and Gear 4 02-19-2005 03:18 PM
