Can you individually adjust the height of a string on a Lo Pro and Edge tremolo? - Jemsite
post #1 of 5 (permalink) Old 12-13-2005, 03:17 PM Thread Starter
I have an Ibanez USA Custom UCEW1QM and would like to know if it is possible to individually adjust the height of a string on this guitar? I'm unsure about what specific trem does it have (it's a Lo Pro or an Edge trem). If it can be done, how do you do it? Thanks.
Econ is offline
post #2 of 5 (permalink) Old 12-13-2005, 04:23 PM
Re: Can you individually adjust the height of a string on a Lo Pro and Edge tremolo?
I remember reading somewhere that you can use shims, small shavings of wood under the string you want higher
eatsleepplayguitar is offline
post #3 of 5 (permalink) Old 12-13-2005, 07:29 PM
I always use thin metal washers around the small screws that mount the saddles to the trem. Works fine.
horstausmforst is offline
post #4 of 5 (permalink) Old 12-13-2005, 07:52 PM
You use saddle shims ... which are thin rectangular metal shims which sit under the saddle and are held in place by the saddle screw. They aren't easy to find though. Try Rich Harris.
ryanb is offline
post #5 of 5 (permalink) Old 12-13-2005, 08:26 PM Thread Starter
Thanks guys. I'll certainly contact Rich to see if he has them.
Econ is offline
edge trem , ibanez usa custom
Ibanez EDGE tremolo manual; slacking the strings, action height? abstract_noise All Other Guitars (including Prestige) 4 04-24-2014 02:31 PM
Cant lower the trem height to adjust the action!!! caribbean77 All Other Guitars (including Prestige) 4 05-24-2012 10:55 PM
Edge Pro Tremolo arm height MozenBee Tech: Setup, Repairs and Mods 1 02-03-2010 04:48 PM
curious tech question, string height before truss adjust? Ki swordsman Tech: Setup, Repairs and Mods 4 06-07-2006 07:38 PM
ZR Trem height adjust? dogmotor All Other Guitars (including Prestige) 4 12-10-2003 07:19 PM
