Can you use condensed air on the js2410 volume pot? - Jemsite
post #1 of 4 (permalink) Old 10-16-2017, 11:31 AM Thread Starter
Seems a little scratchy at low volumes, wondering if it?s entirely enclosed or if I could aim some condensed air somewhere and clean it out? If I can?t, where do I order a replacement?
Sugar is offline
post #2 of 4 (permalink) Old 10-16-2017, 01:21 PM
Re: Can you use condensed air on the js2410 volume pot?
I wouldn't recommend compressed air, but you can try spraying it with a contact cleaner like DeoxIT D100. You can spray it from the top (after removing the knob) and/or from the rear cavity.
If that doesn't solve the issue, the part number is 3VR1J500AS. You can order it direct from Ibanez or from Rich at Ibanez Rules. This 500K Bournes pot should also work.
DeeJayK is offline
post #3 of 4 (permalink) Old 10-16-2017, 03:50 PM
95% of the time a scratchy pot can be cleaned by just working the pot in the scratchy spot back and forth as many times an necessary until it clears. I haven't sprayed contact cleaner in a pot in years.
Rich is offline
post #4 of 4 (permalink) Old 10-16-2017, 09:45 PM
yep most pots are self lubricating
LACS-plus is offline
Tone pot acting like a volume pot... RGFREAK Tech: Setup, Repairs and Mods 6 05-10-2011 12:38 AM
Volume pot ShredderJoshW Pickups & wiring 0 10-14-2008 03:52 AM
RG2570 tone pot! volume pot! walter123 All Other Guitars (including Prestige) 7 07-02-2007 10:22 AM
Volume Pot johnnyd529 Ibanez JEM, UV, JS & Other Signature Models 2 05-09-2006 07:07 PM
new volume pot .. athlon Pickups & wiring 7 02-03-2004 11:31 AM
