Can't intonate low E on my Jem Jr - Jemsite
 2Likes
  • 1 Post By Rich
  • 1 Post By Takin' a Ride
post #1 of 9 (permalink) Old 11-04-2017, 12:23 PM Thread Starter
I can't seem to intonate my low E string on my 2016 Jem Jr. I removed the saddles when I installed a big brass block but think I got the saddles installed correctly.
I have the saddle for the low E as close to the neck as it can get yet the 12th fret is still flat :/ It's difficult to see what note it is exactly because the tuner starts moving back & forth when plucking the fretted note - guess it has to do with the tremolo?
Anyone had a similar problem & know what to do?
linus is offline
post #2 of 9 (permalink) Old 11-04-2017, 12:25 PM
Re: Can't intonate low E on my Jem Jr
Yup, lower the bridge pickup, alot.
Demogorgos likes this.
Rich is offline
post #3 of 9 (permalink) Old 11-15-2017, 03:38 AM Thread Starter
It solved the problem! Thanks!
Is there a permanent solution or will I need to lower the pickup every time I intonate?
linus is offline
post #4 of 9 (permalink) Old 11-15-2017, 03:49 AM
You should probably leave pickup down, to have intonation all time. Or change pickup for one with less magnetic pull.
peromucho7 is offline
post #5 of 9 (permalink) Old 11-15-2017, 03:56 AM Thread Starter
The pickup was parallel to the body - I never had a pickup that low but usually leave the bridge pickup at ~1,5 - 2mm distance to string, when fretting the last note, & 2 - 2,5mm for the neck pickup. I've never had this problem before, but I never used ceramic pickups before either..
linus is offline
post #6 of 9 (permalink) Old 06-11-2018, 04:21 AM Thread Starter
Is there a permanent solution for this problem?
Feels bad to have to lower the pickups Everytime I need to intonate.
Will replacing the ceramic Quantum's with Alnico 5 pickups help?
linus is offline
post #7 of 9 (permalink) Old 06-11-2018, 08:55 AM
That pickup height is pretty high. DiMarzio recommends a starting point of 2.5 mm on the bridge pickup when fretting the last fret. I'd drop them at least until there if not lower. You'll get better intonation and sustain as a bonus.
jemsite likes this.
Takin' a Ride is offline
post #8 of 9 (permalink) Old 06-11-2018, 10:36 PM
Keep in mind that wound strings put out a lot more harmonics & subharmonics than unwound. The closer the pickup is, the more it will transmit to the output jack. That is what was driving your tuner nuts. It can't soft through all the harmonics to find a signal that matches the reference frequency. Bass strings are even worse.
snaggleyoda is offline
post #9 of 9 (permalink) Old 06-12-2018, 10:15 AM
site founder 0% owner
jemsite's Avatar
the tuner is not the issue it's the excessive magnetic pull. Just lower the pickup & keep them lower.
jemsite is offline
low e intonation problems
Satriani's uber low action. How low is too low & how does he bend? JS 1000 Setup. themaidenmaniac Tech: Setup, Repairs and Mods 11 07-01-2012 04:48 PM
Low B on Universe won't intonate Paw Tech: Setup, Repairs and Mods 20 01-06-2010 12:02 PM
How often to intonate? kirk Tech: Setup, Repairs and Mods 22 11-18-2006 12:54 PM
So, how are we supposed to intonate our bridges? themaidenmaniac Tech: Setup, Repairs and Mods 8 07-11-2006 02:26 AM
D string refuses to intonate illumina Tech: Setup, Repairs and Mods 0 08-01-2003 03:32 PM
