Changing Edge Zero 2 Trem Arm holder - Jemsite
post #1 of 6 (permalink) Old 09-26-2018, 06:38 AM Thread Starter
Hi there,
I've got an Edge Zero 2 Tremolo and I find its tremolo arm system kind of annoying, so I was trying to find a solution to change it to something that actually work well for me.
I'm trying to change the tremolo arm system to a pop-in kind of system. I know the Edge Pro and Lo-Pro bridges have that kind of system, but I wanted to know if any of you have tried this before? Do the arm holders from these bridges fit on an Edge Zero 2 bridge?
What is the width of the arm holder hole on a Lo-Pro bridge, for example?
Thanks in advance
adonis is offline
post #2 of 6 (permalink) Old 09-26-2018, 07:51 AM
Re: Changing Edge Zero 2 Trem Arm holder
Originally Posted by adonis View Post
Hi there,
Thanks in advance
It's M10, if that's what you mean by 'width'. The baseplate of the Lo-Pro is threaded to accept the arm holder which is screwed in, then a nut is fitted to lock it in place.
I suspect the Edge Zero 2 baseplate is not similarly threaded so, no, you probably couldn't retrofit the Lo-Pro holder.
sepulchrave is offline
post #3 of 6 (permalink) Old 09-26-2018, 08:46 AM Thread Starter
But if you don't thread the bridge, you can still screw the arm holder tight, right? I'm thinking the thread is probably just for an aesthetic reason.
adonis is offline
post #4 of 6 (permalink) Old 09-26-2018, 11:12 AM
No, the arm socket has no flange and relies on the thread to hold it in place, so it would just drop straight through. Engineers don't thread fastenings for aesthetics dude.
post #5 of 6 (permalink) Old 03-22-2019, 05:11 PM
Couldnít you just use a washer under the head of the socket to keep it from falling through and then tighten it in place with the nut from the back side?
BuggyMasters is offline
post #6 of 6 (permalink) Old 03-22-2019, 05:13 PM
Hereís a pic of the standard edge socket
File Type: jpeg 4286B6CD-3128-49BC-A4F2-101EFFC4CCBD.jpeg (519.9 KB, 10 views)
arm , edge-zero , holder , tremolo
Edge zero II arm holder fix guitar2be Tech: Setup, Repairs and Mods 2 11-30-2016 06:16 PM
Edge Zero arm holder in Edge Pro? DrJustice Tech: Setup, Repairs and Mods 4 07-26-2010 04:24 PM
WTB: Trem Arm holder for Ibanez Edge trem Dale Classified Ads: Guitars and Gear 1 11-10-2007 10:17 AM
edge pro tremolo arm and arm holder adjustment tonesponge All Other Guitars (including Prestige) 6 10-12-2006 04:43 PM
aedge pro tremolo arm and arm holder adjustment tonesponge Tech: Setup, Repairs and Mods 1 10-06-2006 09:16 AM
