Changing trem in Jem style project guitarist - Jemsite
post #1 of 6 (permalink) Old 03-09-2012, 12:37 AM Thread Starter
Changing trem in Jem style project.
Hello all I've been working on a Jem style project. Ive now started working on replacing the trem. I chose a Floyd Lowpro. The body I purchased has the trem mounting stud grommets of some other trem and they have to be changed. Does Anyone know of a trick for pulling those grommets so I can install the correct ones? Your time in advance appreciated.
scott050366 is offline
post #2 of 6 (permalink) Old 03-09-2012, 03:39 AM
Reviews: 120
Re: Changing trem in Jem style project guitarist
Check out project guitar for a tutorial on it.
www.projectguitar.com
LonePhantom is offline
post #3 of 6 (permalink) Old 03-09-2012, 07:19 AM
Claw side of the hammer.
sebastian is offline
post #4 of 6 (permalink) Old 03-09-2012, 07:50 AM
If the grommets are hollow through like a cylinder, you can put a small screw inside into the wood on the body, wind it in about halfway, then screw the trem stud in, and once it hits the screw and starts to lock solid, it should then start to lift the grommet out as it's turned.
Mark_McQ is offline
post #5 of 6 (permalink) Old 03-11-2012, 04:58 AM Thread Starter
Thanks guys for the replies and Mark_McQ your tip worked like butter? Thank you very much!
Scott
post #6 of 6 (permalink) Old 03-12-2012, 10:30 PM Thread Starter
Hey guys so now I'm at the point of using the dremmel tool and take out the extra wood. Is there a number of distance from the trem to the body of the guitar for how much wood needs to be removed? I can find a measurement.
Thanks
floyd , jem , project , tremolo
New Project started..JEM style nato101010 Ibanez JEM, UV, JS & Other Signature Models 128 08-22-2011 04:28 AM
Ibanez Style Project for sale Radeon Classified Ads: Guitars and Gear 4 04-28-2011 10:34 AM
New Ibanez JPM7 style project! jazzedout All Other Guitars (including Prestige) 49 08-23-2010 09:49 AM
FS: One of a kind Jem style project dannybigtime Classified Ads: Guitars and Gear 1 04-25-2009 12:08 PM
changing trem..help dannyooi_84 Tech: Setup, Repairs and Mods 37 12-06-2008 09:05 PM
