Cleaning a floating bridge - Jemsite
post #1 of 16 (permalink) Old 09-10-2011, 11:24 AM Thread Starter
Hey, so my trem is looking a little (well, alot) worse for wear and it's seen beter days. Does anyone have any advice about how to clean in the trem cavity and right up against the saddles?
Chris22 is offline
post #2 of 16 (permalink) Old 09-10-2011, 12:24 PM
Re: Cleaning a floating bridge
Yup. Fully disassemble the unit, soak in 1/3 light machine oil, 2/3 naphtha for several hours. Then remove the parts, scrub with a brass bristle brush and q tips and rag. Then reassemble and enjoy.
musikron is offline
post #3 of 16 (permalink) Old 09-10-2011, 12:55 PM Thread Starter
Thanks, also what strings would you recomend for someone who sweats more than a christmas turkey when playing :P ? Currently use D'addario EXL 110's but they discolour after about 2 weeks of 1-2 hour a day playing
Chris22 is offline
post #4 of 16 (permalink) Old 09-10-2011, 01:09 PM
Reviews: 98
Coated strings!
AlaskaBat is offline
post #5 of 16 (permalink) Old 09-10-2011, 01:11 PM Thread Starter
I've heard about Elixir nanoweb strings but people have had mixed results. Do you have any brand preferences?
Chris22 is offline
post #6 of 16 (permalink) Old 09-10-2011, 08:39 PM
Thanks,Currently use D'addario EXL 110's but they discolour after about 2 weeks of 1-2 hour a day playing
Well that is completely normal. Strings go bad. They also sound like crap well before they feel that way. I would just change strings once a week, buy them in bulk and its really pretty cheap.
Coated strings feel "newer" for longer, but they still lose tone, and they have a degraded tone from the start. They just encourage you to keep playing on dead strings long after you should have changed them.
musikron is offline
post #7 of 16 (permalink) Old 09-10-2011, 08:56 PM
I usually clean trems with naptha, vinegar or just spit depending on what's on them. I use a toothbrush and q-tips to do the cleaning. Wear gloves if you use naptha! I use WD40 on all the hardware.
Takin' a Ride is offline
post #8 of 16 (permalink) Old 09-10-2011, 09:58 PM
I use elixir nanoweb lights. I absolutely LOVE THEM. They play and sound great all the way until i break one, then i change sets. I really can't tell the difference between an old set and a new set.
I'd say give them a go. I used to use Ernie Ball slinky's, but they rusted WAY too quickly for me. Then i moved onto D'addarrio XL, and they work nicely (my favorite non-coated string), they still rusted and had to change them every 2-4 weeks though. The elixir's, i've only ever changed them when i snap one and they sound really good to me up until that point. (WARNING! They are slippery compared to XL's and Slinky's.... but i love that slipperiness)
I put a couple of youtube vids up the other day, and snapped a string like a day or 2 later. So you can check the kind of sound quality before breaking elixirs at www.youtube.com/julzius (check out the ones with bright orange background)
Seriously man, just try them and see how you go.
Toodles, Julz.
julzius is offline
post #9 of 16 (permalink) Old 09-11-2011, 02:48 PM
I've been working on a RG470 for a friend. Last week I got a fret job done on it with brand new strings installed. I played it a week and they were still new looking. He played it one night and three days later when I pulled it back out of the case the string were very corroded. I think he sweats acid. Anyway, we make sure he washes his hands before playing now and after playing I wipe the strings down with Krud Kutter (a light citrus based cleaner) and they put a little Dunlop Lemon oil on a rag and wipe the string down with that. They seem to stay corrosion free for 2-3 weeks now.
gideond is offline
post #10 of 16 (permalink) Old 09-11-2011, 03:03 PM
RGTFanatic's Avatar
Guys, strings are not meant to last more than 2 weeks....3 max with regular playing. Like Musikron said, your playing on dead strings. You can't extend the life of a string by keeping corrosion off. The strings degrade from playing them even if you wear surgical gloves the whole time.
RGTFanatic is offline
post #11 of 16 (permalink) Old 09-11-2011, 03:12 PM
Reviews: 64
Tampax strings all the way
6fingers is offline
post #12 of 16 (permalink) Old 09-11-2011, 03:14 PM
Reviews: 64
Wrong.
You can keep the same strings for more than 5 years cause tone...................is in the fingers!
6fingers is offline
post #13 of 16 (permalink) Old 09-21-2011, 10:26 AM
After playing, I wipe down my strings with a rag soaked in 99% isopropyl alcohol (rubbing alcohol from the drug store). I make sure the rag surrounds the string and then wipe it up and down the neck. Do one string at a time. The strings literally ring out while doing this. It removes all the junk. I'll use the same rag to wipe don the metal part of my guitar to remove sweat, grease, crap, etc.
My strings will be corrosion free for months and I usually change them out once one breaks.
I wouldn't recommend any oil based product just because it will attract dirt.
djem is offline
post #14 of 16 (permalink) Old 09-23-2011, 09:22 AM
I cleaned an old floyd copy by disassembling it and soaking all the parts overnight in coca-cola.
the next day I rinsed everything, dried with a hairdryer and reassembled.
worked great!
abracadabra is offline
post #15 of 16 (permalink) Old 09-23-2011, 10:06 AM
Another thing to consider is cleaning metal parts in a varsol bath. That's how machine shops typically clean all their metal parts.
djem is offline
bridge , cleaning , floating , ibanez , trem
Floating Bridge angle? Shredragrammaton Tech: Setup, Repairs and Mods 14 02-07-2009 05:13 PM
Tuning a floating bridge werx Ibanez JEM, UV, JS & Other Signature Models 8 04-10-2007 10:22 AM
Blocked floating bridge Professor Jones All Other Guitars (including Prestige) 5 02-24-2006 09:13 PM
Disable Floating Bridge eatsleepplayguitar Tech: Setup, Repairs and Mods 6 12-17-2005 01:35 PM
fixed bridge on a floating bridge ibanez..questions Ki swordsman Tech: Setup, Repairs and Mods 15 10-17-2005 07:43 PM
