Cleaning Satin neck? - Jemsite
post #1 of 15 (permalink) Old 06-20-2011, 10:54 PM Thread Starter
Reviews: 4
Yeah, I searched, didin't answer my question.
So I've got a '00 RG520, It's got (or at least *had*) a nice satin neck. Well, I had an outdoor thing at a graduation about 10 days ago, and when I got home, my neck was as sticky and friction-ful as possible. So naturally I tried to clean it up with a cloth (dry, duh). and after that didn't satisfy me, I took some 0000 steel wool to it. Well, that mostly helped. but it's still just not as butter smooth as it was before. I dont think I steel-wool'd down to the wood because in the light it still has that hint of gloss to it.
So can you guys tell me how to get it super-smooth again?
thx
Rock!
FD
PS: how can I polish the frets to a mirror? I know it's not necissary, but wold be pretty cool
fwd0120 is offline
post #2 of 15 (permalink) Old 06-20-2011, 11:02 PM
Reviews: 120
Re: Cleaning Satin neck?
Not sure about the neck, but 0000 steel wool on the frets will shine them up nicely.
LonePhantom is offline
post #3 of 15 (permalink) Old 06-20-2011, 11:09 PM
Reviews: 11
My wolfgang is pretty grungy. Ill do a how to for you tomorrow, including fret polishing.
Supplies needed
600 and 800 grit sandpaper
0000 steel wool
rubbing compound, cheap is fine
Masking tape for rosewood
lint free rags
clean tube sock (not kidding lol)
boiled linseed oil
The process is time consuming but easy to do.
linuxpenguin is offline
post #4 of 15 (permalink) Old 06-21-2011, 04:41 AM
When I refinished my neck, I used naphtha (lighter fluid) to clean my neck. It worked great at removing all the oils and dirt. I also use it to clean all my hardware too.
xXLinkageXx is offline
post #5 of 15 (permalink) Old 06-21-2011, 08:04 AM
Naptha works real well, as does ammonia. Just use it on a rag and try to keep it off the fretboard.
Takin' a Ride is offline
post #6 of 15 (permalink) Old 06-21-2011, 10:21 AM
Reviews: 11
naptha (aka lighter fluid) is a petroleum distallate and solvent, and would potentially eat away at your finish... Id be careful using it. On bare wood it will dry it out.
post #7 of 15 (permalink) Old 06-21-2011, 12:05 PM
These are the best things ever for polishing frets. Does a MUCH better job than 0000 in about 1/4 the time.
http://www.stewmac.com/shop/Finishin..._Up_Stick.html
musikron is offline
post #8 of 15 (permalink) Old 06-21-2011, 12:44 PM
I should of added "use it sparingly and only if really needed." It will easily dissolve just about any gunk though. You can also try good old fashioned spit. You'd be surprised what it can dissolve.
I used the paper version of these. You'll never use steel wool again .
http://www.stewmac.com/shop/Finishin...ng_Papers.html
http://www.stewmac.com/shop/Finishin...sives_Kit.html
post #9 of 15 (permalink) Old 06-21-2011, 12:49 PM
Ayrton's Avatar
Naphta is fine on a poly finished neck.
You can use that or household rubbing alcohol to remove any oils or grime.
Ayrton is offline
post #10 of 15 (permalink) Old 06-21-2011, 01:10 PM
Reviews: 11
You can use almost anything on poly
Guys, just wait till my article when I get home, polishing frets is super duper easy, and cheaper, then using sand paper sticks or steel wool. It also works better.
post #11 of 15 (permalink) Old 06-21-2011, 04:45 PM
I use naptha all the time. It has absolutely no impact on the finish. But it does dry the hell out of the wood, which is why I said keep it off the fretboard.
post #12 of 15 (permalink) Old 06-21-2011, 04:57 PM
Reviews: 11
If its drying out rosewood, what makes you think its not drying out maple? lol you cant see it because its lighter, but its doing the same thing.
post #13 of 15 (permalink) Old 06-21-2011, 06:23 PM
Because there's a clear finish over the maple
post #14 of 15 (permalink) Old 06-21-2011, 06:38 PM
Not always. I like my maple/maple necks unfinished.
The Euphor is offline
post #15 of 15 (permalink) Old 06-21-2011, 06:55 PM
Reviews: 11
As ayrton pointed out, its ok on poly. Oil/satin finishes, not so much.
Maple Neck Care - Satin Gun Oil Finish Sickbean Tech: Setup, Repairs and Mods 27 11-24-2010 09:15 AM
Nooby Question: Cleaning the neck (not fretboard, neck!) mango_icecream Tech: Setup, Repairs and Mods 8 05-12-2008 09:03 PM
550 Neck cleaning??? poiter All Other Guitars (including Prestige) 3 02-15-2007 05:47 AM
Ink on satin finish neck BigShred Tech: Setup, Repairs and Mods 3 06-21-2006 09:52 PM
DBK Neck Cleaning Solution ? Gixxer Ibanez JEM, UV, JS & Other Signature Models 24 09-01-2003 11:19 AM
