cleaning up the noise - Jemsite
post #1 of 16 (permalink) Old 12-15-2011, 08:42 AM Thread Starter
So I have been tweaking my sound and I think I finally nailed it, but I'm getting all kinds of feed back and it's driving me nuts. Is there a way to keep the volume and distortion while having a clean smooth sound?
topher5150 is offline
post #2 of 16 (permalink) Old 12-15-2011, 09:00 AM
Re: cleaning up the noise
Volume knob.
Or get a noise reducer. Personally, I'm using a Decimator ProRack G to clean up the hiss and unwanted feedback.
dcord is offline
post #3 of 16 (permalink) Old 12-15-2011, 09:19 AM
What pickups and rig are you using?
sebastian is offline
post #4 of 16 (permalink) Old 12-15-2011, 09:40 AM Thread Starter
I'm using the Steve Vai EVO pickup on my Ibanez, and either a Jackson, or Charvel humbucker(two coil pickups) on my Charvel avenger
this is how i run it:
Morley ABY--Boss BCB-60 pedal board--Boss TU-80 Tuner--Morley Bad Horsie Wah--Cusack Tube Screamer--Boss MT-2 Metal Zone--Boss GE-7 Equalizer--Dan-electro Hashbrowns flanger--Dan-electro Dan-echo--out the Pedal board and into my Peavey Delta Blues 210
post #5 of 16 (permalink) Old 12-15-2011, 09:53 AM
Too many pedals and patch cables.
I use a TriAxis and 2:90 with volume beyond noon during our rehearsals, one straight into the other, 500 ms delay in the loop, and that equipment requires no noise gate or noise supressor at all.
Typhon is offline
post #6 of 16 (permalink) Old 12-15-2011, 10:47 AM Thread Starter
what if i rout the flanger and echo through the effects loop on the amp
post #7 of 16 (permalink) Old 12-15-2011, 12:30 PM
Are you running all of these at the same time?
post #8 of 16 (permalink) Old 12-15-2011, 12:48 PM Thread Starter
I only use the equalizer with either the two distortion pedals, but i only use one distortion pedal at a time.
post #9 of 16 (permalink) Old 12-15-2011, 01:51 PM
Get an ISP Decimator and your'e done
dragsternj is offline
post #10 of 16 (permalink) Old 12-15-2011, 01:53 PM
jb4674's Avatar
Reviews: 18
Get a compressor and learn to use the effects loop
Jimmy
jb4674 is offline
post #11 of 16 (permalink) Old 12-15-2011, 02:13 PM
If you run a noise gate in the loop after the gain and before the delay or reverb, you get the noise down.
post #12 of 16 (permalink) Old 12-15-2011, 02:42 PM
Quality cables, quality powersupply
Noise gate etc. are a last resort. You shouldn't have any big noise issues unless something is wrong or you are using extreme amounts of amplification ( distortion, compression, etc. )
EL-CeeDee is offline
post #13 of 16 (permalink) Old 12-15-2011, 03:27 PM Thread Starter
What do you mean exactly by extreme amounts of amplification.
post #14 of 16 (permalink) Old 12-15-2011, 03:42 PM
RGTFanatic's Avatar
put a boss NS-1 (noise suppressor) in front of the ABY and clamp it down tight. this will tell you if the noise is coming from you guitar or your effects chain........if it's in the chain, you'll need to back off your gain on each pedal til you find the offender(s). If none of this helps, put the NS-1 in your effects loop.
FWIW...I think you have too many pedals in one chain.
edit: My GE-7 adds a LOT of hiss...this would be a good place to start.
RGTFanatic is offline
post #15 of 16 (permalink) Old 12-16-2011, 02:27 AM
When amplifying your guitar signal, you are also amplifying the noise floor. Making small issues become quite big. Distortion is an amplifier, so is a compressor, an equalizer and ofcourse, so is your amplifier. So when you have lots of amplification, you will have more noise since the small noises earlier in the signal chain will become more apparent.
In my opinion, noise clamps, gates decimators etc. are usually unneeded. Usually there is some culprit, bad cables, bad power supplies, faulty pedals, daisy chains, bad shielding, etc.
buzzing , feedback , noise
Noise Gate VS. Noise Suppressor xSoDopeImHeroinx Gear, Equipment, Recording & Off Topic 22 09-22-2011 12:00 PM
Noise Cleaning Software dark_void86 Gear, Equipment, Recording & Off Topic 4 10-13-2010 06:20 PM
nasty noise from prestige rg (that high fret warbling noise that you DONT want) superhairycamel Tech: Setup, Repairs and Mods 10 07-04-2008 08:00 AM
Jem cleaning Monte454SS Ibanez JEM, UV, JS & Other Signature Models 20 06-03-2001 10:41 PM
noise - ringing noise chip james Ibanez JEM, UV, JS & Other Signature Models 6 01-15-2001 07:08 PM
