clicking sound on pull-up - Jemsite
post #1 of 7 (permalink) Old 02-15-2004, 12:34 PM Thread Starter
This is a little weird, but _sometimes_ when I pull up on my trem, I hear a metallic clicking sound. The reason it's weird is that it's not all the time. It seems like it's only when I first pick up the guitar. after working the whammy bar for a while, the sound goes away. But I don't know what's causing it, because I'm pretty sure the only contact between the bridge and the guitar is at the contact points between the knives and the posts.
Has anybody else has this before? it's pretty annoying to have to do a bunch of pull-ups every time I pick up the guitar to get rid of that metallic click.
thanks,
Jeff.
jeffrg270 is offline
post #2 of 7 (permalink) Old 02-15-2004, 01:16 PM
Try tightening the nut (very slightly, dont do too much) it sounds like it's slightly loose.
That's what fixed my identical problem.
Artist is offline
post #3 of 7 (permalink) Old 02-15-2004, 03:53 PM Thread Starter
I should have mentioned, the metallic click sounds like it's coming from the bridge, not the neck...that's why I looked for any contact down there. Is this the same problem you had? I wouldn't think my problem would be caused by the nut, but I will give it a try.
post #4 of 7 (permalink) Old 02-15-2004, 04:01 PM
me too
I noticed exactly the same thing last night before I took the neck off. I never did figure out what the trem was hitting to make the clicking noise, though. After I readjusted the neck, I didn't hear the noise anymore (of course, I also raised the trem, too).
bachle7 is offline
post #5 of 7 (permalink) Old 02-15-2004, 08:03 PM
Sounds like a bad stud to me. Gotoh has old machines and occasionall;y you'll get a groove right in the V, it will click as it moves over it either up or down.
Rich is offline
post #6 of 7 (permalink) Old 02-16-2004, 11:20 AM Thread Starter
But these are the studs I got from you, rich! :-) Do you think it might be something to do with the springs?
-J
post #7 of 7 (permalink) Old 02-16-2004, 12:00 PM
It's not like I can pre-test every stud
If you want to rule it out throw another stud in.
Rich is offline
tremolo pull -up or return -> knocking sound radix Tech: Setup, Repairs and Mods 7 06-02-2010 06:50 AM
Lo-Pro Edge trem arm clicking MT01 Tech: Setup, Repairs and Mods 2 11-11-2008 10:43 PM
Clicking Whammy BlackToothGrin All Other Guitars (including Prestige) 7 09-28-2007 09:40 AM
clicking sound on my ibby.... rone12 Tech: Setup, Repairs and Mods 15 01-04-2007 12:35 AM
Clicking neck wangbar Tech: Setup, Repairs and Mods 11 02-29-2004 03:40 PM
