Could i change the 2 position switch of my RG620x to a 3 position switch? - Jemsite
post #1 of 5 (permalink) Old 04-23-2007, 11:55 AM Thread Starter
Hi,
First tell that i used the search thing but no answer to my question,so thanks in advance to all the people that read this and try to help me.
I own a 2001 Ibanez RG620x, this is the old model that have the 2 positions mini switch where you can select or the magnetics pickups or the piezo sound.
If i am not wrong, in 2002 Ibanez add a 3 position mini switch where you can select: the magnetics pickups, the piezo sound and mix both together.
My question is:
Could i change the 2 position switch of my 2001 RG620x to a 3 position switch (on/on/on) without any mod like in the 2002 Rg620x? is the LR Baggs board the same in both models?
If i can do this change or upgrade to my guitar, how must i wire the board with the new 3 positions mini switch?
Thanks so much again for read this, and if someone did before this or know how to do it, i will be very thankful for the help.
Last edited by supergirl20_06; 04-23-2007 at 11:56 AM. Reason: mistake in the text
supergirl20_06 is offline
post #2 of 5 (permalink) Old 04-23-2007, 03:00 PM
Re: Could i change the 2 position switch of my RG620x to a 3 position switch?
Change the switch and following the wiring on the newer RG620x.
buddroyce is offline
post #3 of 5 (permalink) Old 04-25-2007, 04:22 PM Thread Starter
Thanks for your help buddroyce but today, thanks to the member horstausmforst i knew that my guitar is not a RG620x, it is a strange RG520x, so your advice will not works with my guitar.
Anyway thanks so much for your answer and your time helping me.
post #4 of 5 (permalink) Old 04-25-2007, 04:55 PM
I'm pretty sure if you wire it up like a newer 620x it will work dude.
newbieguitarmaker is offline
post #5 of 5 (permalink) Old 05-10-2007, 05:27 AM
it will work. the laws of electro magnetics are greater than the laws of ibanez model numbering. get a 3way and wire it up
xeroparadox is offline
RG620x could i change the 2 position switch to a 3 position switch without any mod? supergirl20_06 Pickups & wiring 6 04-25-2007 07:12 AM
After adding a push/pull switch... cowcowcow Tech: Setup, Repairs and Mods 3 03-26-2002 08:39 AM
